Author Topic: Relay question (adding relay to Oscars LED driver board) - it works!  (Read 8173 times)
JoyMonkey
  • Voodoo Wiki Master . . .
    • JoyMonkey.com
I've got these cathode lights hooked up behind my cocktail cabinet's control panels, they work great, but I'd like to add a relay so they only light during gameplay. I can use an AdvMame script to set the Scroll Lock LED to only light up when a game is being played.
My question is how do I get the scroll lock LED to control the cathode light? What kind of relay do I need?
« Last Edit: June 17, 2005, 07:09:32 pm by JoyMonkey »
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
Re: Relay question (use keyboard LED to control 12v light)
« Reply #1 on: May 24, 2005, 02:03:30 pm »
I would use a SPST relay, but a SPDT or DPDT would work fine also.  It will need to switch off of a 5V supply but it will need to draw a low amount of current, I would find one that is rated at a nominal wattage of 200 milliwatts or so.    As far as the current flowing thru the relay to your cathode lights, a rating of 1 amp should be fine.
JoyMonkey
    • JoyMonkey.com
« Reply #2 on: May 24, 2005, 02:24:00 pm »
Do you think  this relay would do the trick?
Sorry, I'm a little clueless when it comes to this electronical lark.
Popcorrin
« Reply #3 on: May 24, 2005, 02:57:23 pm »
That should be perfect.
JoyMonkey
    • JoyMonkey.com
« Reply #4 on: May 24, 2005, 02:59:33 pm »
Cool. Thanks!
Chris
    • Chris's MAME Cabinet
« Reply #5 on: May 24, 2005, 03:31:23 pm »
Isn't this really a job for a transistor?
--Chris
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #6 on: May 25, 2005, 12:46:24 am »
You should probably be using a relay AND a transistor.  Driving a relay from the keyboard lights will probably destroy the LED driver circuitry eventually.
NiN^_^NiN
« Reply #7 on: May 25, 2005, 05:54:05 am »
Sorry to butt in on this thread but is it possible to have a relay do a push button action (short 2 pins) for a second then go back to normal when 12v is applied?
Like say i turned on a 12v device can a relay short the power button pins on my pc for 1 or 2 seconds then stop shorting them while the 12v stays on?
ShinAce
  • Last login:January 16, 2007, 07:38:14 pm
  • Building the unbuildable since 2001
« Reply #8 on: May 25, 2005, 08:48:07 am »
No, not without inventing some kind of RC charging circuit to cause a delay. You're on your own for this one. And please stop jacking threads.
I second the transistor idea. Have the transistor amplify the current from the LED, and then use that to drive a relay. My guess is that the lamp is 10 watts or over, in which case I would not drive it directly from the transistor. That should keep you out of trouble.
An ounce of image is worth a pound of performance.
Popcorrin
« Reply #9 on: May 25, 2005, 10:39:40 am »
Samstag
Popcorrin
JoyMonkey
    • JoyMonkey.com
« Reply #12 on: June 13, 2005, 05:19:26 pm »
Alright, I'm going to try and take this a step further. I thought that seeing as how I'm using the CAPS and NUM LED's anyway, I might as well make up a modified LED board from Oscar's LED Driver Board diagram. The only problem is, I'm still electronically challenged.
Here's a drawing of what I've got so far. The idea is that when the IPac sends the Scroll Lock signal, the relay sends 12V.
I was about to finish this diagram when I had a major brain-fart. Where does the 5V go after it passes through the relay?
And does the rest of this diagram make sense to anyone?
Edit:  I shot the 5V out of the relay into an LED just for the hell of it (kind of makes sense in my tiny brain)
« Last Edit: June 14, 2005, 05:28:26 pm by JoyMonkey »
JoyMonkey
    • JoyMonkey.com
Re: Relay question (adding a relay to Oscar's LED driver board)
« Reply #13 on: June 14, 2005, 08:03:33 am »
I put this thing together last night- only problem is, I'm a little worried that I wired the relay completely arse-ways so I don't want to test it out until someone says it looks right. Can anyone confirm that the above diagram should work?
There was a wiring diagram on the reed relay's package, but it didn't make any sense to me; so I'm a little worried that I might have the 5V going into the relay where the 12V should be and vise versa  :'(
« Last Edit: June 14, 2005, 11:46:18 am by JoyMonkey »
JoyMonkey
    • JoyMonkey.com
« Reply #14 on: June 14, 2005, 01:31:12 pm »
Anyone?  ???
    • GroovyGameGear.com
« Reply #15 on: June 14, 2005, 03:59:43 pm »
Scan the diagram for the relay.  I can't find it online.
JoyMonkey
    • JoyMonkey.com
« Reply #16 on: June 14, 2005, 04:14:50 pm »
Good idea. Here's the relay's diagram...
« Reply #17 on: June 14, 2005, 04:31:41 pm »
That's a good start.
Now, are there any labels on the relay at all ?
If so, post what pin does what.
« Last Edit: June 14, 2005, 04:46:43 pm by RandyT »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #18 on: June 14, 2005, 04:36:25 pm »
yeah, if oyu can get t he marking of the relay that would help.
With my assumption on how relays work..  You send the required voltage through the coil, it creates a magnetic force which "flips the switch" for the NO circuit.
So if I read that pic correctly it can take up to 125V to flip the switch for a 5v rated switch?  or do I have that backwards?
Err, got it backwards, just read the specs on RS's site.
« Last Edit: June 14, 2005, 04:48:21 pm by SirPoonga »
JoyMonkey
    • JoyMonkey.com
« Reply #19 on: June 14, 2005, 04:46:26 pm »
Unfortunately, there are no markings on the relay itself. Here's the photo from the RS website (don't think it's very helpful though). I looked all over for markings and found nothing.
JoyMonkey
    • JoyMonkey.com
« Reply #20 on: June 14, 2005, 05:00:18 pm »
Do you have a meter?
You should get continuity between the 2 coil leads.
Why didn't I think of that!!???
I checked and AB is closed, CD is open
So this means I've got it wired correctly, right?  :o
SirPoonga
  • Puck'em Up
« Reply #21 on: June 14, 2005, 05:03:59 pm »
Would it also be wise to put a diode across the switch of the relay to not allow feedback on that circuit?
I have to find my parallel port circuit again when I was looking at making my qbert knocker.  There was a spike protection circuit on it because relays are notorious for creating spikes when triggered.
« Reply #22 on: June 14, 2005, 05:16:01 pm »
That's what the diode is there for.  IIRC, when power is removed from a coil, the magnetic field collapses and a spike can feed back and damage the circuit.
I think these are referred to as "snubbing" diodes.
(apologies to the EE types if I explained this wrong.)
If you were driving a solenoid (another coil) with the relay, a diode on the switched line would probably be a good idea to help protect the PC power supply.  I don't think a CCFL is an inductive load, so it's probably not a problem here.
« Last Edit: June 17, 2005, 12:08:34 am by RandyT »
SirPoonga
  • Puck'em Up
« Reply #23 on: June 14, 2005, 05:18:02 pm »
Right, but I thought (I need to find that schematic) there was a diode or some sort of spike protection on the switch because when that switch is closed a spike can occur.
I know the diode across the coil is there to prtoect feedback from the coil.
Thinking about it, wouldn't a capacitor inline on the switched circuit supress spikes?
« Last Edit: June 14, 2005, 05:21:27 pm by SirPoonga »
« Reply #24 on: June 14, 2005, 05:22:00 pm »
That would probably be for inductive loads.  I updated my post while you were typing ;)
JoyMonkey
    • JoyMonkey.com
« Reply #25 on: June 14, 2005, 05:26:18 pm »
You are limiting current with the resistor on the other side of the coil because you haveoyn series with the LED. so make sure that the value is proper to run both the LED and the relay.  I think the relay needs 20ma from the specs I looked up.
Also, make sure the LED is connected properly.  If it's backwards, the relay won't work.
Thanks for all the help Randy!
One last question (then I'm done, I swear). I'm not too good at figuring correct resistor values, so what if I removed that resistor and LED completely, what would I connect relay point B to on the LED driver circuit?
« Reply #26 on: June 14, 2005, 05:27:30 pm »
A capacitor will help to protect the contacts of the relay by reducing the arcing that can occur when the contacts are opened and closed a lot.
This is usually only a problem when there is a lot of current flowing through the contacts.
SirPoonga
  • Puck'em Up
« Reply #27 on: June 14, 2005, 05:30:23 pm »
Cool, tha tmakes sense.
So, to answer my other question.  This is the relay I need if I want something from my computer, which most likely will be a 5V source, to trigger the 27V pinball solenoid?
There's a radio shack on my way home.  I might see what they have for power supplies too...
« Reply #28 on: June 14, 2005, 05:32:06 pm »
You may want to put a current limiting resistor in between the B connector and ground.  I'd try about 150ohm for starters and see if it works.  It may not be necessary, but I don't know enough about that relay to know for sure.    The specs I saw called out a 20ma switching requirement, so limiting it to something around there would probably be a good idea.
BTW, don't blame me if it goes *poof*, this info is "AS IS".  But I'm telling you what I would do in this situation and would be comfortable doing ;).
« Last Edit: June 14, 2005, 05:43:35 pm by RandyT »
« Reply #29 on: June 14, 2005, 05:38:49 pm »
According to the specs on the relay (for some reason, I think the ones you posted are different than the ones I got from the RS website) it should be fine.  But I would recommend the diodes and a capacitor for that setup.  You'll be driving an inductive load with a fair amount of current, so better safe than sorry.
JoyMonkey
    • JoyMonkey.com
« Reply #30 on: June 14, 2005, 05:42:46 pm »
Thanks Randy! Once again, you're my hero!  :P
« Reply #31 on: June 14, 2005, 05:44:49 pm »
Make sure you go back and re-read some of the posts.  The edits were flying on this one ;)
Popcorrin
« Reply #32 on: June 15, 2005, 10:07:23 am »
Popcorrin
« Reply #33 on: June 15, 2005, 10:13:00 am »
« Reply #34 on: June 15, 2005, 11:05:42 am »
This particular relay is only rated at .5amp.  Depending on how much your pinball solenoid draws you may need something rated a little higher.
Here's the "other" spec sheet on that relay:
Compact 1-amp SPST Reed Relay
(275-0232)                 Specifications             Faxback Doc. # 35144
Coil: ......................................................... 5 VDC
Coil Current: ................................................. 20 mA
Pick up Voltage: ...............(70% max)................... 3.75 VDC
Drop Out Voltage: ...............(10% min)................... 0.5 VDC
Max. Voltage: ............................................... 7.5 VDC
Coil Resistance: ........................................... 250 Ohms
Temp. Rise: ........................................ 30 degrees C Max
Operate Time: .............................................. 1.5 mSec
Release Time: .............................................. 1.5 mSec
Service Life: ............................ 5,000,000 Operations @ 1 A
Contact Rating: ............................................... 1 Amp
                                                               1 Watt
                                                              125 VAC
Contact Resistance: .................................. 150 milli Ohms
(EB 10/25/96)
It shows a 1-amp at 125volts AC rating for the contacts.  Maybe the half amp rating is for DC?
But based on the other specs,  I stand corrected as it appears to handle even less than .5 amp.  It calls out the power switching spec at only 10 watts!
That would mean that the 30v solenoid (if that's the voltage the solenoid is driven with) could draw only 1/3 of an amp to be used with this relay.  But without knowing the specs of the solenoid, it's hard to say what it draws.  There's also the fact that the solenoid won't really be doing any "work" as a "knocker", just slamming into the wood to make a noise.  So,  the current used would just be enough to momentarily push the rod out of the coil.  I think the current requirement goes up with higher resistance againt the actuator, but this stuff isn't my forte' :)
BTW, SirP, will gravity be used to reset the rod or is there a spring loaded return?
SirPoonga
  • Puck'em Up
« Reply #35 on: June 15, 2005, 11:29:37 am »
See the pic in my qbert thread
http://forum.arcadecontrols.com/index.php/topic,37834.0.html
I can get all the text off the knocker.  I don't think anything about specs was on it.
I will  have to ask OscarControls and 1UP where they got it from.
Long story about the knocker.  I think it started in the hands of Kelsey (OscarControls) when I was first talking about this a couple years ago.  I said I'd do the software side (urebelscum was going to include it into analog+ mame) if he did the hardware.  Well, busy guy he is he handed it off to 1UP.  1UP, I suspect, was busy planning his cabinet venture.  So he now sent the knocker ot me.
If I remember that's how the story goes, but it has been going VERY slow over the last couple of years :)
Hey Randy, not to get off topic, but have you looked at the dartboard thing some more?
SirPoonga
  • Puck'em Up
« Reply #36 on: June 15, 2005, 11:36:34 am »
Doing a quick search all the pinball supply places carry it, but don;t list specs :(
All I could find is
http://members.shaw.ca/cfpinball/gottliebcoil.html
JoyMonkey
    • JoyMonkey.com
« Reply #37 on: June 15, 2005, 10:08:06 pm »
I just tried out the circuit and I've got a problem (hopefully nothing major).
Right now I've got it wired just like the cut-n-pasted diagram above; I hooked up a 150 ohm resistor and a random LED to point B - and they work fine when I hit Scroll Lock, but the relay isn't giving me 12v like I expected. I checked all my connections and everything appears fine.
Could I have picked the wrong resistor? Should I try a higher or lower value resistor?
I was delighted when the LED lit up, but now I'm stumped.  :'(
« Reply #38 on: June 15, 2005, 10:19:13 pm »
First thing, disconnect the 12v lines from the relay.  Energize the circuit and check for continuity through the switching part of the relay (where the 12v lines were)  No continuity means the relay isn't working.
Popcorrin says you shouldn't need a resistor in there (except for the LED) so I would try taking the LED and the resistor out of the circuit and take pin B straight to ground.  There might be a voltage drop or something that the relay doesn't like.
Something to try, anyway.
JoyMonkey
    • JoyMonkey.com
« Reply #39 on: June 15, 2005, 10:46:09 pm »
Okay...
There's no continuity in the relay's switch. I removed the LED and resistor and I've still go the same result.
Could it be the transistor I'm using? I just used what I had at hand (a PNP to 92 transistor 2N3906) which is different to the one's that Oscar uses in the LED driver circuit, but he does say that any general purpose PNP transistor should do.
What happens if I take the 1k resistor out of the equation?
Edit: Just for clarity, here's what I've got right now
« Last Edit: June 15, 2005, 10:55:57 pm by JoyMonkey »
