Author Topic: 1-slot neo geo video problem  (Read 2901 times)
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« on: May 23, 2005, 11:35:44 pm »
Okay I have two boards that are giving me problems.
1.  No sound on a CPS-2 game.  I tried the game in mono and stereo (which shouldn't work anyway).  The on board volume is all the way up and two other boards have sound through the same system.
2. The video at the top is messed up.  I took a picture.   Don't look at my guy getting his ass kicked while I photograph.  Instead look at the top.  The hotizontal shift is the problem.  This is a neo geo 1 slot MV-1FZ PCB.  It has the same problem with all carts and does the same thing in another cabinet.  my two other boards have perfect video throught this setup.
Any thoughts?
« Last Edit: June 03, 2005, 05:11:27 pm by monkeybomb »
monkeybomb
Re: 2 Boards / 2 problems
« Reply #1 on: May 24, 2005, 12:19:44 am »
Problem 1 solved by Tommy.
Thanks again
Q*Bert_OP
  • Oh yes, we did!
« Reply #2 on: June 02, 2005, 09:11:19 pm »
For problem # 2
Look @ the motherboard (A board) for any bent pins on the connectors.
-Kevin
monkeybomb
« Reply #3 on: June 03, 2005, 05:09:41 pm »
Thanks qbert.  I want to make clear that the neo geo boad is the one with the video problem and the CPS2 is fine.
I check the connections on the neo geo board again after you post and everything looked good.  Even the place where the cartridge slides in looks perfect.  :-\ :'(
Q*Bert_OP
  • Oh yes, we did!
Re: 1-slot neo geo video problem
« Reply #4 on: June 04, 2005, 01:18:41 am »
Maybe try some canned air and clean it.
Might be a dust problem.
I also use this stuff made by Chemtronics, it's called Electro-Wash. It cleans the connectors of Pcbs and Neo Geo carts very well.
