Author Topic: How to fix pincushion problems?  (Read 1620 times)
mamerocks87
  • Last login:March 17, 2007, 12:21:33 pm
« on: May 22, 2005, 07:45:31 pm »
The link is to a picture of my wells 27inch standard res monitor. It is a current production model.  As you can see it has a pretty bad pincushion problem.  I have messed with the pincushion controls on the board and this is as good as it gets.  I cant seem to get the little dip out on near the top corners.  My quistion is, what are the first steps I need to take to fix this?  What are the main causes of pincushion problems. Also my monitor gets a  fuzzy out of focus picture after about 10 minutes of being on, would these problems be linked in any way? Thanks for all of the wonderfull help in advance.
http://www.debutvm.com/arcademonitor.jpg
mamerocks87
Re: How to fix pincushion problems?
« Reply #1 on: May 22, 2005, 10:42:46 pm »
could my arcade vga card be the problem?
Ken Layton
  • Guru
  • Technician
« Reply #2 on: May 23, 2005, 12:12:27 am »
How old is this monitor? It sure looks like it could use a capkit.
mamerocks87
« Reply #3 on: May 23, 2005, 12:36:25 am »
Probably has been 6 months (suppose to be... bought it used off ebay) since a capkit.  could that cause the blurryness and the pincushion?
