Author Topic: xevious monitor question  (Read 1701 times)
redfivexw
  • Last login:March 11, 2025, 03:54:00 am
« on: May 16, 2005, 12:07:07 pm »
I got a new monitor for my xevious, and am trying to hook it up but cannot get a good picture.  From the monitor, there are 7 wires, R,G,B, and a white and blue (i assume these are sync), and a black (ground).  The xevious has these wires : R,G,B, then wire calles Vid. Rtn (i have no idea) and sync.  there is no ground coming from the video section that was originally attached to my old monitor.  I connected the RGB, then twisted the white and black wires from the monitor and connected those to sync.  I got a picture but it is very light and has  some green lines running up and down (horizontal as the monitor is in the vertical position).  I connected the vid. rtn to ground and that did nothing.  Does anyone know what i am doing wrong?  What is vid. rtn and where does it connect to?  Should i connect the ground from the monitor somewhere else?
Darth Nuno
  • Last login:May 08, 2024, 04:26:02 pm
  • Namco is God !
    • Arcade Lifestyle / Dragon's Lair Fans
Re: xevious monitor question
« Reply #1 on: November 07, 2005, 04:22:29 pm »
Hi,
I'm also a proud Xevious owner, and I plan to buy a new monitor because the actual is strongly burned  :(
Just for information, did you solve your problem ?
What kind of monitor did you use ?
You can have a look at my xevious here : http://www.dragonslairfans.com/phpBB2/viewtopic.php?t=63
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #2 on: November 07, 2005, 08:36:30 pm »
I used one of these..
http://www.arcadeshop.com/parts.htm#Monitors
looks great in my friends xevious.
(This is the same monitor as the happ one located here)
http://www.happcontrols.com/monitors/49132900.htm
Later,
dabone
