December 02, 2025, 02:50:35 am
Nice fingernails
Also made a pulley. This was neat, as we did everything from start to finish. Made a sand mold to cast the blanks, and then turned it on a lathe. Broached a keyway through the center hole, also drilled and tapped a hole for a set screw. I had fun with this one until I broke the carbide cutting tool on the lathe...
How did u manage to break the turning tool? I assume you just broke the insert? What happened? Just interested as im a CNC turner.
Quote from: Franco on May 14, 2005, 06:52:35 amHow did u manage to break the turning tool? I assume you just broke the insert? What happened? Just interested as im a CNC turner. Well, this wasn't a CNC lathe, it was manual, with power feed, etc... I had the pulley butted up against the chuck, and was turning the outside diameter with a slow feed rate (finishing pass) and I let the tool go just a hair too far, and it hit the chuck, and the chuck broke the carbide tip right off... I was so embarrassed, lol. Luckily, the instructors were cool about it, and just gave me another tip.
Easily done mate, ive had more than my fair share of mishaps!If youve got a cab you should make yourself some stainless or ally joys!
Also made a pulley.
