Author Topic: DirectPad Pro stopped working?  (Read 1350 times)
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« on: May 08, 2005, 02:01:47 pm »
here goes:
about 6 mos ago, I used win98se on an old pc, and had installed DPP5.0 on it, and everything worked fine.  I eventually built a new pc, and tried upgrading to winxp (got the new xp files working,) but for various reasons concerning the OS, formatted and went back to 98se on it.  since then, i have NOT been able to get the DPP files working again on the new pc.  i've tried v5.0 and v6.0.  here's what happens.
I open up the joystick section (gaming options) of the control panel, clicked "add" then "add other" then "have disk".  i find the folder with the DPP files in it, and it installs fine.  however, when i try choosing "directpad pro controller" from the "add" list, i get this message every single time:
(title bar-"missing gameport or gameport drivers")
message-"your gameport or gameport drivers are not properly configured.  please consult the device manager."
i've tried removing and reinstalling in different folders, including c:\windows and c:\windows\system.   nothing works.  there's nothing wrong in the device manager.
after wondering if the cable was screwed up, i downloaded zsnesdos, and found it to be working perfectly fine.
directx is updated to 9.0c, so that's likely not the cause.  I have an integrated sound MB (asus p4s800) but that shouldn't matter, since it's connected to the lpt anyway.
any ideas?
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
_Iz-
  • Last login:March 17, 2026, 09:19:06 pm
  • Time to coin up!
Re: DirectPad Pro stopped working?
« Reply #1 on: May 10, 2005, 03:25:15 pm »
directpad pro requires a gameport driver to be installed (even if one doesn't physically exist on the computer). Dunno why, that's just the way it is. Install the generic microsoft one.
