Author Topic: my cabaret project  (Read 2609 times)
crsdawg
  • Last login:September 13, 2019, 06:10:05 am
  • I plan to live forever, or die trying.
my cabaret project
« on: May 07, 2005, 01:43:53 am »
after building several cabs for other people i figured it's time i should build one for myself.
i picked up this cabaret gyruss conversion on ebay a couple months back and have finally started refurbing the cabinet.
as you can see this cab has seen better days. the lower area has quite a bit of water damage and the top and bottom pieces need to be replaced. not for the weak of heart. i really like this cabs shape and it is just big enough to hold a 19" monitor. i think it deserves another chance at life.
at this point i've dissasembled the cab and have removed some of the bad wood.
next up is to remove some of the lower area that has water damage. once that is done i'll build a new bottom for the cab, then move up and replace the top piece.
« Last Edit: May 26, 2005, 03:15:38 am by crsdawg »
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
Re: my caberet project
« Reply #1 on: May 12, 2005, 08:28:51 pm »
Looks good so far.
Gary
Apollo
    • Eight Bells
« Reply #2 on: May 13, 2005, 01:31:36 am »
Is that tube resting on the neck!?
greven grevs
  • Last login:January 17, 2006, 03:24:19 pm
  • U.S. Air Force
    • The Greven Group
« Reply #3 on: May 13, 2005, 12:46:48 pm »
it sure looks that way.  :o
crsdawg
« Reply #4 on: May 23, 2005, 03:37:29 am »
i finally had sometime to work on my new cab.
« Last Edit: May 23, 2005, 03:45:01 am by crsdawg »
Bloinkxp
  • Last login:August 30, 2020, 11:20:28 am
Re: my cabaret project
« Reply #5 on: May 23, 2005, 01:37:49 pm »
Lookin' Good.  :)
Nothing witty here...move along.
crsdawg
« Reply #6 on: May 26, 2005, 02:58:03 am »
i was able to make some more progress.
new back and top installed
tonight i was able to have a little fun and do something besides replace rotted wood. this is the cd rom/floopy mount. it sits behind the lower coin door.
i know it looks a little crooked in the top pic. it's not my mount but the door. it's hinge is a little bent which causes the door to lean a little. i'll take care of that when i refurb the whole assembly.
i'll also probably build another, taller, coin box. i think the coins/tokens will just bounce out of the current one.
clonestar
  • Last login:March 09, 2009, 04:00:53 pm
  • Thunderbirds are puppets!
« Reply #7 on: May 26, 2005, 11:04:39 am »
This project reminds me of the kids story of the stone soup, where this guy claims he can make soup out of a stone, then adds a bit of salt, then onions etc. you get the picture, untill finally he remove the stone and voila - soup.  What I mean is that oneday you will will end up replacing the last bit of the original and have a completely scratch built cab.
crsdawg
« Reply #8 on: May 26, 2005, 03:22:10 pm »
heh heh , the thought of replacing the sides and front has crossed my mind. since what's left of the original shell is in decent shape i doubt that will happen. you never know.....
