Author Topic: Comments on my first CP  (Read 1785 times)
lustreking
  • Last login:October 11, 2021, 08:43:06 am
  • One Louder
« on: May 05, 2005, 12:00:22 pm »
I'm trying to design my first cp, which will be a
Zeosstud
  • Last login:January 20, 2026, 05:52:04 pm
Re: Comments on my first CP
« Reply #1 on: May 05, 2005, 12:45:07 pm »
Put in a second joystick so you can play Robotron.  Looks fine to me for a 1 player control panel.
Rodney
markrvp
  • NFL Expert
« Reply #2 on: May 05, 2005, 02:34:12 pm »
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
« Reply #3 on: May 05, 2005, 03:22:31 pm »
Make the second one a topfire stick and you can play Battlezone too.
Avery
  • Last login:May 03, 2013, 12:52:02 am
  • Have fun! Make stuff.
« Reply #4 on: May 05, 2005, 05:11:32 pm »
You will end up showing this off to your friends - add a player 2 button to support alternating player games.  It's only another two bucks and a hole.
If you decide to go with the second joystick (as has been suggested), you could still have room for a spinner my making it "slightly modular" and having an interchangeable trackball mounting plate and spinner mounting plate.  They both connect on more or less the same interface.
Avery
quarterstringer
  • Last login:June 19, 2016, 03:35:04 pm
  • Rampart
    • Rampart
« Reply #5 on: May 05, 2005, 06:33:59 pm »
This is not intended to last forever, because I eventually plan to build a cabinet.
This should be the perfect cabinet for your control panel - The LustreKing Bowling Ball Polisher. ;D
lustreking
  • One Louder
« Reply #6 on: May 06, 2005, 01:24:51 pm »
I printed out the template full-size yesterday and it is huge.
markrvp
  • NFL Expert
« Reply #7 on: May 06, 2005, 03:10:12 pm »
Also, move your buttons 1-7 up a little higher so that your hands will rest parallel to each other when playing.
I was thinking the same thing myself.
