Author Topic: Best way to clean rubber grommets on rusty wicos?  (Read 3698 times)
quarterback
« on: April 30, 2005, 02:46:20 pm »
I've read a thread where it says to NOT use WD40 on the wico grommets, but I'm wondering what I should use.
I just got some old wico 8-ways that are a little rusty.  I've taken steel wool to the shafts, 409 to the platic parts and have the metal parts soaking in WD40, but I'm not sure how to clean the grommets.
-- Chad Tower
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
Re: Best way to clean rubber grommets on rusty wicos?
« Reply #1 on: April 30, 2005, 02:52:52 pm »
I washed mine with soap and water.  Then used spray silcone which says it will keep rubber from drying out.  Don't want the grommets to dry out and crack.
quarterback
« Reply #2 on: April 30, 2005, 03:00:28 pm »
-- Chad Tower
Captain_Dingo
  • Last login:November 28, 2018, 05:57:32 pm
« Reply #3 on: April 30, 2005, 03:04:48 pm »
Something that just crossed my mind...
There's a product called "Seal Saver".  It comes in a small bottle.  I have it for keeping the rubber neck and wrist gaskets on a kayaking dryjacket healthy.
Same idea, it prevents the rubber from drying out and cracking.
JODY
Ken Layton
  • Guru
  • Technician
« Reply #5 on: May 01, 2005, 01:15:52 am »
I use Wildcat Products #RC88 Rubber Cleaner. It's the same stuff used to clean pinball machine rubber rings. Works great on all rubber products.
