Author Topic: MAMEWAH Windows XP shell  (Read 2171 times)
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
« on: April 29, 2005, 11:28:02 pm »
I tried changing the shell in Windows XP to mamewah and when it boots it just hangs with a black screen. Is there something else that needs to be changed? I have SP1.
Thanks.
I love the life I lead. I wish I could afford it.
jfunk
  • Last login:October 24, 2018, 04:36:39 pm
  • BYOAC Wannabe
    • JFunk's Arcade
Re: MAMEWAH Windows XP shell
« Reply #1 on: April 29, 2005, 11:57:45 pm »
Have you checked the MAMEWAH log?
I had a similar problem..  Can't remember the steps to fix it, offhand, but a search should turn something up..  I'll try to find it tomorrow, if you haven't, yet.  Check the MAMEWAH log..  You should see some errors you can search for...
Craig
« Reply #2 on: April 30, 2005, 12:07:30 am »
It has one line of this: 30/04/2005 1:12:06 PM Mode 800 x 600 @ 60, 16bit colour not available and 1000 lines of this: 30/04/2005 1:12:07 PM Mode 1024 x 768 @ 60, 32bit colour not available  ???
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
« Reply #3 on: April 30, 2005, 09:44:22 am »
I'm not sure, but I believe it had to do with the Welcome screen or something??? This webiste shows you how to set up most of the MAMEWAH stuff w/ WIndows and mask the Windows appearance - http://www.upup.us/old/2003_09_01_old.html#106469688462437353
jfunk
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #4 on: April 30, 2005, 12:09:14 pm »
lcddream
  • Last login:December 04, 2024, 03:59:31 pm
  • Say goodbye to gravity...
« Reply #5 on: April 30, 2005, 03:28:08 pm »
« Last Edit: April 30, 2005, 03:30:51 pm by lcddream »
Craig
« Reply #6 on: April 30, 2005, 10:51:18 pm »
Thanks. I had to disable the welcome screen and then it worked  :D
