Author Topic: control panel artowrk for...upload?  (Read 1295 times)
Flinkly
  • Last login:March 14, 2017, 01:14:21 pm
« on: April 29, 2005, 11:00:23 pm »
i posted in the stickied thread, but i'm impatient.
« Last Edit: April 29, 2005, 11:08:19 pm by Flinkly »
rohan
  • Last login:December 30, 2011, 08:24:04 pm
  • I'm a winner.
Re: control panel artowrk for...upload?
« Reply #1 on: April 29, 2005, 11:19:55 pm »
Take a high-res photo for reference, combine with the scans into a single zip file and upload it to http://www.localarcade.com  Make sure that if they're in jpeg format, that you're using the lowest level of compression(retains quality the best).  Some one will stitch, correct, and vectorize the artwork when they can.
300 DPI should be fine for vectorization unless there are very tiny things that may not show up at that resolution...You shouldn't need to go higher than that I think.
It doesn't matter if you win or lose....it's how you play the videogame.
Flinkly
« Reply #2 on: April 29, 2005, 11:33:10 pm »
dang...i'm still waiting for that 1200 scan.
« Last Edit: April 30, 2005, 12:26:37 am by Flinkly »
zorg
« Reply #3 on: May 02, 2005, 04:15:27 am »
Flinkly I will produce the zip and up it for you in order to have the scan availables ;)
I'll send you a log and pass to an ftp site.
I'm on the planning stage
