Author Topic: More controls than needed? Help!  (Read 1746 times)
jfunk
  • Last login:October 24, 2018, 04:36:39 pm
  • BYOAC Wannabe
    • JFunk's Arcade
« on: April 28, 2005, 10:03:38 am »
My cabinet's not even done, yet..  But I've been collecting controls since day 1..  I don't have as impressive a collection as some, but I've got more than I need, I think..  My question is, out of these controls, what's the best control panel I can make?  I want it to be able to play a lot of games.. But not be monstrous.
2x T-Stik Pluses with black ball tops
2x P360s
4x Midway 49-ways
1x J-Stik with red ball top
1x 2 1/4" Ultimarc trackball (w/mounting plate)
I've also got an assortment of both regular and competition pushbuttons.  And a 24x8 character LCD I'm trying to figure out how to add...
Is there any other, simple, small, MUST HAVE control?  Thought about spinners, but thinking the TB could do in a pinch..?
I was _PLANNING_ on trying to build swappable control panels.  But there are a couple of problems.  First, I can't figure out a good way to swap the hinged panel tops  :(  The wiring is easy to swap with cat5 cable and ethernet jacks..   2nd, swapping the LCD would be a PAIN!  Also, I'm just not sure it's necessary anymore..?
I was going to have 3 panels, at first:
- Everyday panel: 2 players, 7 buttons per player, trackball, t-stik pluses
- Fighter panel: 2 players, 7 buttons per player, p360s (I really enjoy fighters when my brother comes up, but typically, the first panel would be fine)
- Q-Bert/Congo Bongo panel, angled J-stik, buttons
And then, I could just add new panels (SW yoke panel? spinner panel?) when I get controls..  But, I'm thinking now that's overkill...
I've got my admin buttons, on a separate panel under the monitor.  (P1/P2 start/coin, escape, pause)  So, that should help with the design a bit.  But, what should the rest of an "all-purpose" control panel look like with these available controls?
My available dimensions are:
14 1/2" x 27 3/4"
That's actually the inner dimensions of my currently built CP box.  There's probably another 1/8"+ in each dimension...  Here's what the current CP looks like:
It's using the t-stik pluses and an IPAC4, with the trackball and an optipac, and regular pushbuttons from Ultimarc.
I still like the idea of swappable panels.  Maybe keep my original 3, but add a 4-player panel with the 49-ways..  I keep trying to figure out if there's a stable/secure way to add "wings" to my panel to make it a bit wider for 4-player use.  Would like to NOT angle the joys so I could have 2 player Smash TV/Robotron...  But this all might just be a pipe dream.  Plus, still have to figure out how to swap the tops easily.  Don't want to spend 30 minutes at it each time :(
So, any thoughts?  I'm just looking for ideas/direction..  Once painting is done (everything has stalled, recently, with the birth of my 2nd daughter :)  ) I'll be ready to put it all together!  Except for the CP!
Any/all help greatly appreciated!  THANX!!!!
Flinkly
  • Last login:March 14, 2017, 01:14:21 pm
Re: More controls than needed? Help!
« Reply #1 on: April 28, 2005, 11:11:07 am »
well, if your up for spending the money to get 4 gpwiz49's, i'd say just stick with the 49's for all your joystick needs.  that's my 2 cents.
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
« Reply #2 on: April 28, 2005, 12:56:57 pm »
The everyday/fighter panels seem a little redundant to me unless you're really REALLY picky about how your fighter sticks feel.
(Hey! One of those free keyboards! Haven't seen one of those in ages!)
markrvp
  • NFL Expert
« Reply #3 on: April 28, 2005, 01:56:51 pm »
I am asking and addressing several of the same questions here:
http://forum.arcadecontrols.com/index.php/topic,35938.0.html
jfunk
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #4 on: April 28, 2005, 04:23:40 pm »
Heh.  Yeah, maybe more background is needed  :)  At first, my 'everyday' panel was going to be what I've got described, but instead of 7 buttons/player, only 4 buttons/player.  Less cluttered and plays the majority of the games.
I got anxious, though, and knew it would take longer to get 2 panels created than one, so semi-combined the everyday and fighter.  I was planning, though, on redoing the everyday at one point to be more geared towards the non-fighting genre...
And I'm not terribly picky about feel.  I love the t-stiks..  EXCEPT for fighters  :(
That free keyboard has been used on more little projects of mine..  I never did find an easy way to use those extra buttons :)
Thanx.
jfunk
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #5 on: April 28, 2005, 04:31:41 pm »
OK.  WOW.
I guess I really don't have too many controls after all!!  :)
I'll have to look through that thread  :)  But if anyone has any suggestions on my specifics, I'm all ears  :)
Thanx.
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
« Last Edit: April 28, 2005, 07:49:27 pm by JODY »
