Author Topic: Ultrastyle as shell (3d error msg)  (Read 1025 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« on: April 27, 2005, 10:55:47 pm »
I just setup ultrastyle and was looking to set it to my shell. upon loading it gave me an error about not being able to load some 3d stuff. I went back after explorer loaded and its fine. Is there something that loads after exploere that enables the 3d stuff in ultrastyle? can I load this with ultrastyle as a shell and still nix exploere.exe?
thx
-d88
delta88
Re: Ultrastyle as shell (3d error msg)
« Reply #1 on: April 28, 2005, 08:46:59 pm »
*word*
Witchboard
« Reply #2 on: April 29, 2005, 09:17:16 am »
The only thing I can tell you is to put Ultrastyle in the Run Key in the registry instead of making it the shell.  I know that when you close Ultrastyle it won't shut down your system like it would if it were the shell. ^_^
Where is the Shell Key you are altering in the registry?
delta88
« Reply #3 on: April 29, 2005, 04:26:43 pm »
Well putting it in the run area is just like adding it to the startup folder.. which is what is currently in play on this pc.
 -d88
