Author Topic: Joust to Multi-Williams Replacement Monitor ?  (Read 1373 times)
johnvv
  • Last login:June 19, 2012, 08:36:20 pm
« on: April 26, 2005, 02:02:37 am »
I have a Joust that is in sad shape and will be restoring and updating to a Multi-Williams, despite the negative economics involved...
It still has the orginal monitor, which works fine, but has a fair amout of burn.  I'd like to replace it.  What are the choices for a replacement?  Is one condisdered better that others?
I've seen the Vision Pros at arcadeshop.com for $179.  I found a WG model that was about $300 (lost my notes on it).  I assume some model of 19" Betson will also work.  Will any power changes be needed for these newer monitors?  Yes, I'm a newbie at this.  But the Joust will look great when it is done (new paint, new CPO, new electronics, etc.)
Thanks.  I have done some searching prior to posting this.
Ken Layton
  • Guru
  • Technician
Re: Joust to Multi-Williams Replacement Monitor ?
« Reply #1 on: April 26, 2005, 02:09:17 am »
Yes, the Happ Vision Pro, Betson-Imperial (Kortek), and Wells are all excellent monitors.
