Author Topic: bezel glass -tinted or not tinted  (Read 1920 times)
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« on: November 24, 2002, 11:48:31 am »
I know there exist both of them on arcade machines - but what is common?
What did they use on the 80s classic games, such as Centipede, DonkeyKong, Gyruss?
Is it better to play/look when it's tinted? (e.g. reflections, still enough brightness left with tinted glass?)
JMasSlikStik
  • No-Edit-Allowed
  • Last login:November 24, 2002, 01:42:23 pm
Re:bezel glass -tinted or not tinted
« Reply #1 on: November 24, 2002, 01:45:44 pm »
On my MAME cab, http://www.instantlink.com/mame/ if ya want to see it. I used regualar gray plate glass and I like it, the monitor I used was a 27" television.
JMascari
http://www.slikstik.com
android
  • Last login:August 21, 2006, 09:44:47 am
« Reply #2 on: November 24, 2002, 11:06:06 pm »
My Tron and Centipede use plain see-thru glass / plexi. My Crystal castles and Space Duel use tinted glass. I personally prefer tinted glass as you see less of the monitor. Although brightness may suffer a bit, I think overall it looks better with tinted glass. Old monitors are brownish and the tinted glass hides that, particularly for games that have big black areas. I don't think Space Duel (vector) would look as good without the tinted glass.
Carsten Carlos
« Reply #3 on: November 26, 2002, 12:40:35 pm »
Thanks, guess I'll go with tinted glass! :) Black areas should look much better in vector or something like Gyruss.
