Author Topic: Arcade Cabinet Restoration  (Read 1234 times)
Ler6557
  • Last login:May 07, 2006, 08:47:22 pm
« on: April 16, 2005, 10:57:19 pm »
Hi. I was wondering if anybody could point out to me a certain cabinet, who has seen many more than I. I am looking for a Centipede or Asteroids type cabinet except I want the top parallel to the bottom like the modification of the Centipede the PacMAMEA included with such a feature. Basically what I'm looking for is an Asteroids upright with a monitor area that can fit a bigger screen and a straigh instead of angled control panel. I need a cabinet that has a fairly big control panel support as I am going to install a SlikStik QUAD. Lastly, I need a base big enough to install an over/under 4 player coin door and perhaps a hinged door there also. Any suggestions would be great so I can look them up and see if they're what I'm looking for so I can buy it. Thanks.
Bones
  • [Moderator]
Re: Arcade Cabinet Restoration
« Reply #1 on: April 17, 2005, 08:40:55 am »
I can't help you with your question but maybe do some clicking around at www.klov.com and you might snag what you are looking for.
Good luck!
