Author Topic: Mounting computer components  (Read 1964 times)
D5A1AC
« on: April 15, 2005, 08:01:05 am »
Hi all, I'm a long time viewer of this site, first time poster. I have made myself a cocktail cabinet and I am waiting for my buttons, joysticks and ipac to arrive. While I wait, I would like to mount all the components of my arcade pc inside the cabinet. It would be easy to glue some blocks on the side of the cabinet and screw the motherboard in, but what I am worried about is the pci cards (namely a geforce 2 and ethernet card). How would I go about securing those because I cant just leave them hanging in the air. If anyone has any tips on mounting them or any other hardware (psu, hdds, opticals etc) please share your wisdom  :) If this Issue has been addressed before I'm sorry, please just provide the link to it.
Thanks for your help
From Mike.
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
Re: Mounting computer components
« Reply #1 on: April 15, 2005, 08:22:46 am »
honestly, those cards are really light.. shouldnt have to worry to much unless your going to constantly be tripping over the ethernet cord..
or just glue another BIG block of wood on that side of the motherboard and screw them down.. no biggy
paigeoliver
  • Awesome face!
« Reply #2 on: April 15, 2005, 08:34:56 am »
You can also start with a complete PC case and chop it up until it is just the mobo plate and the back plate.
SteveJ34
  • Last login:January 06, 2024, 12:29:40 am
« Reply #3 on: April 15, 2005, 09:11:59 am »
Yep....this is where an old case, handy dandy dremel and a couple of cutting wheels comes in handy.
Let the sparks fly...
D5A1AC
« Reply #4 on: April 15, 2005, 09:42:12 am »
Wow what a fast reply! Thanks - I was considering making some sort of block to drill the cards onto. I was worried that the thick monitor cable would snap the graphics card or a card would evetually come loose. I had also considered the "hack the cr*p out of a case until youve got the bare minimum"option but I dont like to ruin things hehe. I suppose If the blocks dont work, ill try to find a banged up case on the side of the road and keep the original one intact.
By the way, I've just made a quick site about my cabinet if you'd like to see it?
you can go to www.mikesarcade.tk but tk seems to be acting odd, so if that doesnt work you can try http://www.freewebs.com/minifileserver/mamesite/index.htm
bishmasterb
  • Last login:March 23, 2014, 09:27:47 pm
  • Pressing the limits of my wife's patience...
    • Bishopzone
« Reply #5 on: April 15, 2005, 12:57:35 pm »
That's what I've done before and it has worked out well. The motherboard plate (part of the case that the mobo attaches to) is typically held in place by rivets that can be separated cleanly from the rest of the case.
"We have just enough religion to make us hate, but not enough to make us love one another." -Jonathan Swift
whammoed
  • Last login:Today at 09:56:11 am
  • Crack don't smoke itself
    • NiceMite
« Reply #6 on: April 15, 2005, 02:13:34 pm »
I just bent some aluminum flat bar to hold the cards:
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #7 on: April 15, 2005, 07:08:34 pm »
Just go get a small, thin piece of wood (1x1?) and stand it straight up beside your card's screw holes.  Pre drill the holes and screw your cards into them just as if you were mounting it in a computer case.
Flack
  • Last login:December 18, 2025, 08:24:18 am
  • The Commodork
    • Rob's Homepage
« Reply #8 on: April 15, 2005, 07:33:11 pm »
My MAME Cabinet has a PC motherboard mounted to the side and has three cards plugged into it (video card, NIC, and sound card). It's been like that for a year or so and I've never had a problem.
.xX Flack Xx.
ArcadeMaze
  • No-Edit-Allowed
  • Last login:April 11, 2025, 01:36:59 pm
« Reply #9 on: April 15, 2005, 07:58:28 pm »
Yep, I took the case and dremelled away most of it, but left part of the rear of the case to support the power supply and the cards.
D5A1AC
« Reply #10 on: April 15, 2005, 10:29:35 pm »
Okay, I think I'll take a closer look at the case (It looked like the mobo plate and backplate would separate from the rest fairly easily), and If I can get it out without too much damage I'll try using the backplate and mobo tray. I can always just pop rivet it back in if it doesn't work. I think ill go with that idea rather than the wooden blocks because it should make it a little easier if I were to put another pci card in. I was thinking of a wifi card and then I could set it up on our network and have a nice media centre pc too  ;D
Thanks everyone
