Author Topic: Salmon King Minimum Req.  (Read 2144 times)
owenowen
  • Last login:August 04, 2007, 04:15:59 am
« on: April 12, 2005, 07:21:00 am »
Can any one tell me if Salmon King would work on a P2? 500mhz with 64 mb of ram? In not what would?
cheers,
owen.
SalmonKing
  • Last login:August 16, 2007, 10:45:44 am
  • SK Jukebox
Re: Salmon King Minimum Req.
« Reply #1 on: April 12, 2005, 07:14:33 pm »
cheers,
owen.
Would I work on it?  Not a chance...not after working on a P4 2.8 for the last 18 months   ;D
As for my software, well, it's worth a shot!  I have it working on a P3 800, so it might work on your setup.  You might not be able to animate the album changes as it may be a little too much for it to handle.
As I generally say to people who ask if the software will work on their setup - "If it's a Windows 98 (or onwards) system, it should work.  How well it works....well, you will find out once you install it & try!"   ;)
owenowen
« Reply #2 on: April 13, 2005, 05:20:39 am »
Ill Give it a go then !
