Author Topic: can somone check my wiring? (pic)  (Read 1258 times)
kenzo42
  • Last login:November 23, 2024, 01:11:32 pm
« on: April 12, 2005, 02:21:52 am »
http://pg.photos.yahoo.com/ph/liu_feng_yi/detail?.dir=/3917&.dnm=1d8c.jpg&.src=ph
http://pg.photos.yahoo.com/ph/liu_feng_yi/detail?.dir=/7922&.dnm=2c8b.jpg&.src=ph
so this is my wiring for my dreamcast to arcade monitor:
--5v wire connected to 1ohm 25 watt resistor connected to ground. i guess it looks like this... 5v-----{resistor}-----ground. it's in the pic at the right side.
can resistors be installed backwards?
--12, N, 13 from jamma finger connected to RGB from DC vga monitor cable pins #1,2,3
--P (sync) from JF connected to hor and vert sync (twisted together) from monitor cable 13 & 14
--14 (ground) from JF connected to ground from monitor cable pin #10
how does a picture look on a computer monitor when it is running at 15khz, if it actually displays something?
thanks.
« Last Edit: April 12, 2005, 02:23:56 am by kenzo42 »
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
Re: can somone check my wiring? (pic)
« Reply #1 on: April 12, 2005, 03:08:48 am »
Resistors can be placed either way.
I have to squint to see the pictures.  :o :o
I love the life I lead. I wish I could afford it.
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #2 on: April 12, 2005, 10:28:41 pm »
Where did you get those boards, did you actually buy them from the site listed on them?  Im looking for some cheap boards and I heard they are like 2 bucks at most.
kenzo42
« Reply #3 on: April 13, 2005, 12:25:14 am »
