Author Topic: How do I set up a joystick in MameWAH?  (Read 1256 times)
Timstuff
  • Last login:April 16, 2014, 02:24:29 am
  • I feel asleep !!
« on: April 11, 2005, 10:35:36 pm »
I read some of the docs that it came with, but I still don't know where to enable the joystick from. Does anyone have any advice?
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
Re: How do I set up a joystick in MameWAH?
« Reply #1 on: April 12, 2005, 12:04:24 am »
If you mean a "Windows" joystick then look in the Ctrlr folder. There should be a file, default.ini. Under the "Settings" section you can enable the joystick and/or mouse to scroll your gamelist.
John
Timstuff
  • I feel asleep !!
« Reply #2 on: April 12, 2005, 12:17:37 am »
Well, I meant setting it up so that it will use a joystick in the games by default, but thanks for the info anyway.
jcrouse
    • CPViewer
« Reply #3 on: April 12, 2005, 08:04:50 am »
I believe that would be a function of the emulator not the front end, MameWAH.
John
