Author Topic: E Stick questions  (Read 1165 times)
scuzzie
  • Last login:November 28, 2008, 06:54:23 pm
E Stick questions
« on: April 09, 2005, 11:06:34 pm »
I'm building a cabinet at the moment and bought a couple of E-Stick joysticks - 3 questions . . .
1 - do the two notches under the coverplate against the shaft  signify anything like up/down or are they just molding bits?
2 - does it matter which way up they go?
3 - which of the gold and silver contacts is the earth?
Any help would be greatly appreciated.
thanks
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
Re: E Stick questions
« Reply #1 on: April 10, 2005, 01:36:30 am »
They're just there to keep the assembly from rotating once it's installed...they don't serve any "mechanical" purpose.  Bear in mind that you'll have to notch out the top of your wood or plexi to match these nothces.
Nope.  I have mine side-to-side, but it doesn't really matter
The silver are the "common ground" contacts.
