Author Topic: Power without a PC?!  (Read 1341 times)
Jellyman_4eva
  • Last login:January 26, 2006, 04:21:22 am
« on: April 08, 2005, 04:58:13 pm »
Hi all,
Just a quick question for an expert I guess! I want to use illuminated buttons on my control panel. The panel is using an USB IPAC. However the control panel is actually a seperate unit to the rest of the arcade machine (Where my PC is), my control panel controls link with a USB cable which goes from my control panel to the arcade machine, but how can I get power easily for my control panel!! I was thinking of just using a PSU on its own (As it has the necessary 12V + 5V I need and I aint no electrician!) but without a motherboard how do I make it come on!!
I would prefer a more elegant solution but as of yet I can not think of one... any help?!
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
Re: Power without a PC?!
« Reply #1 on: April 08, 2005, 05:07:52 pm »
You short 2 pins, I forget which ones.
Can't you use the 5v a USB cable (or iPac) supplies?  Do those things need 12v?  You'd probably be best to make a custom connection.  Use a 6-pin connector that you make, for the 4 USB connections and some powers.
oldsage
  • Last login:December 19, 2005, 09:11:47 pm
  • Does SHMIGRUB ring any bells??
« Reply #2 on: April 08, 2005, 05:19:02 pm »
I had a cool sig once... But it had to go because of *someone*... You know who you are!
daywane
  • GRRRR!
« Reply #3 on: April 08, 2005, 06:55:08 pm »
you could also get the older style pc power supply
not atx. I can not think of the name right now.
you do not have to short out the two wire on them
or an old arcade power supply. those you can adjust the voltage
Goz
  • KOTA
« Reply #4 on: April 08, 2005, 07:03:15 pm »
Pins 14 and 15 on an ATX PSU will simulate a load and power up the PSU.
Here's the pinout for a std ATX PSU
Hope it helps
-Goz
psik0tik
  • Last login:March 09, 2008, 11:32:31 pm
  • Bah Bah Bah
« Reply #5 on: April 08, 2005, 11:39:07 pm »
you can use a AT power supply.. they didnt get switched off by the motherboard. They have theyre own switch and cheappppp.
Going to Mcdonalds for a salad is like going to a crack house for vitamins.
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
« Reply #6 on: April 08, 2005, 11:45:28 pm »
Hope it helps
-Goz
Yup... Connect a wire between the green wire & a black wire...
It'll work then.
- tmasman
I'm not a freak!...
Oh wait...
Yes I am...
Franco
« Reply #7 on: April 09, 2005, 05:21:57 am »
Just incase this helps to clarify things further.
