Author Topic: winIpac shift help  (Read 3289 times)
Keller888
  • Last login:September 26, 2007, 09:31:43 pm
  • I love the smell of solder in the morning!
winIpac shift help
« on: April 07, 2005, 01:35:56 pm »
How in the devil do you assign shifted keys using the Ipac4????  I have all my buttons assigned, that was easy.  I want to give some buttons "shifted" assignments, such as the ~ (tilde) key, for getting into that menu while in MAME.  I can't figure it out.  I know i am missing something simple, help before i start beating my wife for no reason!!
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
Re: winIpac shift help
« Reply #1 on: April 07, 2005, 01:56:25 pm »
I'll field this one...
Winipac software.  Select shifted player 1-2 tab.  Assign keys.  Select shifter 3-4 tab.  Assign keys :P
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« Reply #2 on: April 07, 2005, 02:10:52 pm »
Or go into the table view.
Can someone verify if I'm understanding the shift purpose? I think I get it, but I can't understand why you would use it.
The idea is that if I hold down the "shift" button then all my other buttons are suddenly mapped differently?
Or is that pressing the shift button toggles between shifted and unshifted?
I guess the problem is, on a cabinet, it doesn't make much sense to allow the user to F@#$ up the settings. So I want to make it a whole lot more difficult to get at anything other than the standard joystick and button presses. I figure I'm missing the point. :(
Joseph Elwell.
Keller888
« Reply #3 on: April 07, 2005, 11:34:08 pm »
ok, do i have to have a button wired into a special slot on the Ipac4 board, meaning, is the Ipac4 looking for a botton already marked as a right or left shift key?  Or do I pick a button on my control panel, and assign that button to be the shift key by highlighting the cp button and then hitting the Left Shift button on the keyboard I have connected to the pass-through?  This is where I think i'm losing it.
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #4 on: April 08, 2005, 12:14:42 am »
the "Shift" button on the IPAC is not actully the shift key on your keyboard. I have my shift key set to v if i remember correctly. I can't remember off the top of my head how to set it, bvut its in there, I know on the IPAC2 the shift key is player1 start as default, so try that.
