Author Topic: Project 64 version 1.6 is out  (Read 7934 times)
JCKnife
  • Last login:November 04, 2008, 09:41:57 pm
« on: April 05, 2005, 11:36:00 am »
Not sure if this belongs here or in consoles but Project 64 has a new version, 1.6 released recently.
http://www.pj64.net/iedefault.htm
Todd H
  • Last login:August 26, 2024, 02:23:32 pm
  • It's Gameday!
Re: Project 64 version 1.6 is out
« Reply #1 on: April 05, 2005, 12:29:11 pm »
Can't wait to try this out when I get home.  Thanks!   :)
mbmsog
  • Last login:September 22, 2006, 01:04:23 pm
« Reply #2 on: April 05, 2005, 01:35:52 pm »
so how long do you think till we will see a new wrapper?
for mamewah?
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
« Reply #3 on: April 05, 2005, 04:16:55 pm »
Just finished it.
John
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
« Reply #4 on: April 05, 2005, 04:28:18 pm »
It been 5 hours since this was first posted...man, I thought you were faster than that! ;D
JCKnife
« Reply #5 on: April 05, 2005, 04:58:58 pm »
Todd H
  • It's Gameday!
« Reply #6 on: April 05, 2005, 05:04:12 pm »
I've been playing around with 1.6 for about half an hour.  It looks like there's some pretty nice improvements, especially in the areas of speed and compatibility.  Waverace 64 is now pretty much perfect (as far as I can tell).  Let's see what plugins come in the next few months to improve things even more.
p.s. I'm with JCKnife, where's the link?   :)
jcrouse
    • CPViewer
« Reply #7 on: April 05, 2005, 05:32:39 pm »
I just posted them on my web site at http://home.comcast.net/~cpviewer . It's up to you to find them, I can't do all the work for ya.
Enjoy,
John
PS...Not much testing was done. Email me directly if you have problems. I'll get right on them. Remember to edit the cfg file.
mbmsog
« Reply #8 on: April 05, 2005, 05:41:38 pm »
You ARE ALWSOME!!
Thanks for the fast great update!!
Also it works great for me not bugs that i can find yet!
Todd H
  • It's Gameday!
« Reply #9 on: April 05, 2005, 05:54:18 pm »
Working fine for me as well.   :)
jcrouse
    • CPViewer
« Reply #10 on: April 05, 2005, 05:55:20 pm »
I'm just updating my cab now!
Works here also!
« Last Edit: April 05, 2005, 06:04:16 pm by jcrouse »
JCKnife
« Reply #11 on: April 05, 2005, 08:27:49 pm »
John, thanks for the file. I'm getting this error:
Edit: NEVERMIND. Found a typo in my .cfg edit.
« Last Edit: April 05, 2005, 08:34:05 pm by JCKnife »
JCKnife
« Reply #12 on: April 05, 2005, 10:58:19 pm »
Okay I'm still having a (different) problem...when I start from mamewah, p64 does not recognize any controller (keyboard) inputs. This is true whether I use my cp or the actual keyboard. I can't find any way to get to a config menu in p64 when I launch from mamewah. What am I missing?
RoboG2
  • P&R
  • Last login:August 15, 2008, 10:21:26 pm
« Reply #13 on: April 06, 2005, 07:24:51 am »
Same here.  When I start Project 64 by itself, everything is fine.  When I start it through MAMEwah without the wrapper, it's fine also, but I can't exit.  When I start it through MAMEwah with the wrapper, I cannot use any keyboard input, but I can escape.  Any Ideas?
jcrouse
    • CPViewer
« Reply #14 on: April 06, 2005, 07:39:13 am »
Well, I've seen this before. It's a focus issue. Even though the app (P64) is on top, it doesn't have focus. Try messing with the {dosbox} and or {safelaunch} parameters. It's probably the {nosafelaunch}. Try changing it to {safelaunch}.
John
Todd H
  • It's Gameday!
« Reply #15 on: April 06, 2005, 08:28:58 am »
I haven't had any of the controller or focus issues, although I sometimes see the Project 64 window in Mamewah as it loads a game.  As for the controller issue, did you set up your controllers before loading it with Mamewah?  And did you install 1.6 in a new folder or in the same folder as the older version?
jcrouse
    • CPViewer
« Reply #16 on: April 06, 2005, 08:33:36 am »
I also, ocasionally, see a window flash.
John
JCKnife
« Reply #17 on: April 06, 2005, 10:25:02 am »
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #18 on: April 06, 2005, 12:03:09 pm »
John
  Hey John,  why don't you make your wrapper start up P64 minimized (or hidden, if you can) then maximize it after a timeout (configurable), say 1500ms?
  I wonder if that would solve anything.  Plus, it would make it more attractive for people to use.
-sab
Zeosstud
  • Last login:February 24, 2026, 05:32:44 pm
« Reply #19 on: April 06, 2005, 12:05:15 pm »
For me, the key was getting my computer updated.
jcrouse
    • CPViewer
vibez
  • Last login:February 09, 2011, 08:33:20 am
« Reply #21 on: April 06, 2005, 01:06:59 pm »
This looks interesting. before I try to set this up, can anyone tell me if I have enough buttons on my cab to make running project64 worthwhile... Its a 2 player control panel with 6 buttons per player
JCKnife
« Reply #22 on: April 06, 2005, 01:17:38 pm »
With six buttons per player, something's gotta give. N64 controller had 10 buttons, analog stick, and a d-pad. So if you map your stick to the analog, and your start button to start, that still leaves 9 buttons and 4 d-pad directions but only 6 action buttons.
Several games you can play fine, but for example tetrisphere (a favorite) uses the d-pad which I didn't map to anythiing.
Mario Kart, Wave Race, etc. are fine.
jcrouse
    • CPViewer
« Reply #23 on: April 06, 2005, 01:21:31 pm »
However, don't forget that if you have access to a USB port you can use either an original gamepad with an adapter or a Logitech Pad as a windows device. I added a USB port right on the front of my CP about a month ago.
John
vibez
« Reply #24 on: April 06, 2005, 01:28:35 pm »
Thanks for the info guys. I think i'll leave this off my cab for now. I could plug a joypad into it, but I already have project 64 on my xbox so I think i'll keep on there for now
Zeosstud
« Reply #25 on: April 06, 2005, 02:53:41 pm »
Thats just crazy talk.  You need it on your cab too, here is why.  Lets say the wife is half drunk and listening to her music on the xbox upstairs.  7 year old has friends over and they are playing Barbie Horse Adventure on the Living room xbox.  You are in the basement, the stars have aligned, xlink kai is working and your buddy in St Louis wants to play Co-Op Doom3 with you on the basement xbox, where is your 3 year old boy gonna play Mario Kart 64?  What, the bedroom xbox. heck no, the damn dog is asleep in there and he isnt old enough to play on the one in the car by himself.  Thats why you need it working on your cab, too.
Zeosstud
jcrouse
    • CPViewer
« Reply #26 on: April 06, 2005, 03:16:00 pm »
YEAH! What he said. (Just what the hell did he say?)
 :o
John
RoboG2
  • P&R
« Reply #27 on: April 06, 2005, 03:32:42 pm »
 :o  I wish I had that many xboxes!
vibez
« Reply #28 on: April 06, 2005, 04:12:53 pm »
oh man, that was the funniest thing i've read in ages! Ok i'm convinced to give it a whirl. Me & my GF are always fighting over the TV anyway. What shall I map to each button/stick to get maximum compatabilty?
RoboG2
  • P&R
« Reply #29 on: April 06, 2005, 04:33:44 pm »
I changed {nosafelaunch} to {safelaunch} and it worked like a charm!  Thanks for the advice.
Zeosstud
« Reply #30 on: April 06, 2005, 05:26:18 pm »
On my cab I mapped Player 1 Analog Stick like this:
A=L Cntl
B=L Alt
S(tart)=Space
Thats the bottom row of a standard fighter layout starting on the right and going left.
Z=L Shift
R(ight)=X
L(eft)=Z
That would be the top row of a standard fighter starting on the right and going left.
I also mapped the C buttons to the Player 2 joystick so I could play Robotron64.  I have no idea if this is standard or not, hell I was just trying to get it setup so Mario Kart worked.
I used the same logic while setting up the analog stick for Player 2
Zeosstud
vibez
« Reply #31 on: April 06, 2005, 06:03:04 pm »
thanks Zeosstud. That setup seems to work great :)
JCKnife
« Reply #32 on: April 06, 2005, 09:20:19 pm »
jcrouse
    • CPViewer
« Reply #33 on: April 06, 2005, 09:36:29 pm »
In my limited experience with MameWAH that setting, {safelaunch}/{nosafelaunch} seems to vary from system to system. I can't add any more than that other than a friend of mine and I work on the setting up of our cabinets together and what works on one cabinet doesn't ALWAYS work on the other even though the OS and SP level is the same AND the speed of the components, mobo and CPU are almost identical. It's something to do with focus. MinWAH and I have talked about it and don't really have an explanation.
Later,
John
Zeosstud
Button Warning!!!
« Reply #34 on: April 07, 2005, 08:50:51 am »
In an earlier post I mentioned that I had mapped the C buttons to the player 2 joystick, found out last night when I actually played a 2 player game of Crusin Exotica and Rush 2049 that odd things happen when this is used.  Specifically your view changes (Player 1) and a few other odd ball things.  The setup is fine for Robotron 64 but as a default setup, if you will be playing 2 player games, its a bust!!
Zeosstud
vibez
« Reply #35 on: April 07, 2005, 11:15:56 am »
Yeah I ignored that part as I like a 2 player setup. Apart from that most games seem to work fine with those settings. thanks
JCKnife
« Reply #36 on: April 08, 2005, 09:26:53 pm »
Hee hee! I just bought 2 NIB Adaptoids on ebay and after the auction I see the seller's e-mail is "@wishtech.com" !
Musta had some leftover stock.  ;D
drunkatuw
  • Last login:April 24, 2025, 02:25:30 pm
    • Drunk at UW.com
« Reply #37 on: April 13, 2005, 10:56:45 am »
I installed Project 64 with the wrapper last night and ran into a few problems.  When I select a game, the screen just turns black.  If I alt+tab, I can get to project 64, but the game is not maximized.
I changed the settings so that it should start maximized everytime, but the setting doesn't seem to stick.  I was wondering if this is because of a focus issue (I've never had a focus issue, so I'm not really sure what the symptoms are), or is it a problem with the wrapper not saving the settings or could this be a bug in the new version of project 64?  I used to have project 64 1.5 (downloaded modified version from screenshotarchive) on my old computer and didn't not have this problem, but I want to try 1.6 for the new speed improvements.
jcrouse
    • CPViewer
« Reply #38 on: April 14, 2005, 09:52:43 am »
LOL, did you even read the thread and try the different dosbox and launch settings?
John
vartech
  • Last login:March 20, 2013, 03:38:17 pm
  • The Great Swordsman Hiko
« Reply #39 on: April 15, 2005, 04:44:31 pm »
Need help p64 is working fine I lanch from Mamewah but when I hit the exit button it just goes to a smaller screen and not back to mamewah any Ideas? ???
