Author Topic: mounting 4 way pacman/galaga reunion...allternate ways???  (Read 3719 times)
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« on: April 04, 2005, 05:18:50 pm »
okay so im making a classics cab for a friend and all it needs is one 4 way joystick for donkey kong, frogger, etc.  i dont have a router, and i know that the 4 way needs a mounting plate to sit correctly.  my question is, is there another way for me mount it?  or is there an easier, or better way to get 4 way functionality without having to use a router to recess a section in the wood?  thanks for your help in advance.
shmokes
  • Don't tread on me.
    • Jake Moses
Re: mounting 4 way pacman/galaga reunion...allternate ways???
« Reply #1 on: April 04, 2005, 05:32:47 pm »
I believe RandyT's replacement handles will fit in that base and the length is adjustable so mounting it on the underside of a wooden control panel wouldn't be a problem.  I guess, though, that ordering a replacement handle is no easier than ordering a mounting plate so maybe this doesn't help.
Best Kid iPad Apps
whammoed
  • Last login:Yesterday at 09:29:46 am
  • Crack don't smoke itself
    • NiceMite
« Reply #2 on: April 04, 2005, 05:33:29 pm »
You could get a replacement handle from groovygamegear.
shmokes
    • Jake Moses
« Reply #3 on: April 04, 2005, 05:36:41 pm »
p.s.  RandyT and Groovygamegear are one and the same, Hulkster, in case you thought you might like to look at both options and decide which one sounds better :)
Best Kid iPad Apps
Apollo
    • Eight Bells
« Reply #4 on: April 04, 2005, 05:39:50 pm »
If you are making a classics cab then how about using a red ball top T-stick plus, there are a lot of "classic games" that are 8 way that you may want to include.....1942, Gyruss, Scramble, Juno-First, Exed-Exes the list goes on and on.
hulkster
« Reply #5 on: April 04, 2005, 11:01:31 pm »
links?
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: April 05, 2005, 08:21:14 am »
Groovy Game Gear Replacement Shafts (under Joysticks in the shopping cart section)
Lilwolf
« Reply #7 on: April 05, 2005, 08:37:02 am »
btw, I like the mounting brackets from Bob Roberts MUCH better then from the Happs ones.
Bob Roberts ones are flat.  and 10 bucks or something.  Cheap.
hulkster
« Reply #8 on: April 05, 2005, 08:45:26 am »
which one do you recommend?
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: April 05, 2005, 08:49:18 am »
You mean color, texture, and size?  (Your preference!)
hulkster
« Reply #10 on: April 05, 2005, 08:56:58 am »
so im guessing the omni-stick is the best choice here.  my question is, can this be mounted underneath 3/4" mdf without any recessed section or mounting plate?
Tiger-Heli
    • Tiger-Heli
« Reply #11 on: April 05, 2005, 09:05:40 am »
Whoa, Doggie - I thought you already had a reunion stick.  If so, you could mount it below panel with one of RandyT's Versa-ball joystick shafts.  If not, the Omni-Stick with the mounting plate is a good choice (roughly $25), but you do have about 1/10" 5x5 plate above the CP.  Otherwise the E-Stick or T-Stick from www.ultimarc.com is an option, although I don't like the fascia on the E-Stick, and (from what I've read) not sure about the stiff springs/short travel of the T-stick.
hulkster
« Reply #12 on: April 05, 2005, 09:09:04 am »
okay, i DO have a reunion joystick, but i dont have a router to recess a section in the cp.  so what im wanting is a dedicated 4 way joystick that can be mounted similar to the super 8's from happ.  all i want to do is drill a hole in the cp and mount a 4 way joystick underneath just as i would a super 8.  understand?  if  you know of a way to do this with my existing reunion joystick, i would be happy to hear it.
Tiger-Heli
    • Tiger-Heli
« Reply #13 on: April 05, 2005, 09:15:48 am »
Okay, back to square one - Go to the link I posted above for the Versaball joystick shafts (they start at $11.99).  Pick out the appropriate color, texture, size, etc. (your choice).  Pick up a dust washer ($1.99) if you need one (don't have one lying around).  Remove reunion joystick shaft, mount reunion joystick to bottom of panel, install Versa-ball shaft at desired height.
You might want to try this in scrap 1x4 first.  You might want to verify with RandyT that the Versaball shaft works with the reunion stick.
hulkster
« Reply #14 on: April 05, 2005, 09:32:48 am »
okay i will check with RandyT....im guessing he is the owner of the website you gave me a link to?  also, i have never seen a dust washer i dont think....is that the black plastic ring that fits around the joystick between your hand and the cp?
Tiger-Heli
    • Tiger-Heli
« Reply #15 on: April 05, 2005, 09:41:57 am »
Correct on both questions.
melarky
  • Last login:July 12, 2020, 12:49:22 pm
  • If I could be any animal, I would be a llama
« Reply #16 on: April 05, 2005, 11:31:44 am »
hulkster
« Reply #17 on: April 05, 2005, 11:45:59 am »
quarterback
« Reply #18 on: April 05, 2005, 11:50:31 am »
as long as the joystick shafts off of RandyT's site work, then it will all work out.
It's been confirmed (in another thread) that they do work
« Last Edit: April 05, 2005, 11:52:21 am by quarterback »
-- Chad Tower
hulkster
« Reply #19 on: April 11, 2005, 10:59:08 am »
okay so im going to go with the shafts from RandyT's site, but i'm wondering which size to get?  im using a 3/4" panel, so will a 1 1/2" joystick be long enough?  (heh)
whammoed
    • NiceMite
« Reply #20 on: April 11, 2005, 11:03:00 am »
hulkster
« Reply #21 on: April 11, 2005, 11:30:52 am »
yes yes, pac man balls....jokes abound.
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #22 on: April 11, 2005, 11:57:18 am »
I know you already have a reunion, but you can get a pac stick from Tornado Terry that will mount in wood as well (just for future reference).
« Last Edit: April 11, 2005, 12:00:07 pm by Nannuu »
Next I'll be on fries, and that's when the big money starts rolling in.
