Author Topic: Playing Star Wars With Analog Joystick  (Read 1711 times)
Skippy2k
  • Last login:October 12, 2006, 12:32:25 pm
« on: April 03, 2005, 04:34:35 pm »
I am trying to play star wars with my analog joystick but it seems when the stick is in the center the sight on screen is at the bottom left of the screen, this makes the game a little difficult and was wondering is it my joystick which needs calibrating in windows or an you calibrate it in mame.
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
Re: Playing Star Wars With Analog Joystick
« Reply #1 on: April 03, 2005, 04:41:55 pm »
Calibrate it in Windows.  It will let you test it there to make sure everything is fine.
Skippy2k
« Reply #2 on: April 03, 2005, 05:02:57 pm »
I have just tried to calibrate it in windows and it seems fine in windows and also the other mame games, its just  star wars its doing it too.
Lilwolf
« Reply #3 on: April 04, 2005, 03:43:07 pm »
mine does this also... with a hydra yoke... But I removed the centering springs (because they where wrong... and none was better then wrong) and I thought that was the problem.
Anyone able to test it?  I would like to know if its a problem myself.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: April 05, 2005, 03:54:24 pm »
I calibrate star wars in mame by moving the stick in all directions.  Four or five full criss-crosses seems to bring it very close to center, but more is better.  After the first game, it seems pretty much centered.  (Can't test at work, but I'll bet rotations work as well as criss-crosses.)
Robin
Knowledge is Power
