Author Topic: Is lexan strong enough to mount buttons?  (Read 2097 times)
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« on: November 15, 2002, 03:29:16 pm »
I'm planning a control panel sandwich made of 5/8" wood, graphics on paper or vinyl, and 1/8" lexan on top. This gives me a pretty standard 3/4" thickness to mount most everything.
The one exception so far is atari cone-style lighted buttons. They came off of a metal CP which is what, 1/16"? It is possible to mount them to 1/8". I'm thinking of cutting holes in the wood where these buttons would go and mounting directly to the lexan.
Are there any foreseeable problems doing it this way?
ErikRuud
Re:Is lexan strong enough to mount buttons?
« Reply #1 on: November 15, 2002, 03:50:32 pm »
You should be ok.  The cone buttons shouldn't be taking a pounding like the larger buttons do.
I would make the whole in the wood as small as possible.
You could also consider using a large washer countersunk into the top surface of the wood, under the overlay.  This would take some of the strain off of the lexan.
« Last Edit: November 15, 2002, 03:52:56 pm by ErikRuud »
American Laser Games Wrapper
O2em Rom Utility
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
« Reply #2 on: November 15, 2002, 04:05:47 pm »
For this application I would say yes. Lexan is some tuff stuff and as the last poster mentioned make the hole in the wood as small as possible. Post some pics how it turns out. I've looked at those atari buttons and think they would look cool.
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
Brad Lee
    • 666
« Reply #3 on: November 15, 2002, 04:10:17 pm »
They're actually from a Omega Race cp- Midway, but the switches are exactly the same, slightly different cones
They were all stuck and nasty, but a little bit of alcohol, elbow grease, and lots of clicking the mechanism, is all it took to get em back into good shape. I just wish there was a way to light all 4  through the keyboard or Ipac.
I'll probably cut a square hole  in the wood for each of them, since thats the shape of the switch under the cone, that should help keep it from spinning
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
« Reply #4 on: November 15, 2002, 05:23:54 pm »
Whatever you do..MAKE double sure that you print overlay on vinyl.The material is amezing.You cant even make any scratch even if you tried on purpose.I am finally happy..just so you know..as soon as I get my serial port fixed then i can post a pic and you can take a look(it will convince you to go vinyl ;D).
