Author Topic: AVGA MAME Resolution Tool problem  (Read 1481 times)
Breaker
  • Last login:December 10, 2024, 11:38:20 am
« on: March 29, 2005, 12:28:49 am »
Hi all,
I think I have a problem with the AVGA MAME Res Tool.
I have been using the tool for a few weeks now tweaking resolution settings and it has been working perfectly. However this evening I noticed that it wasn't pulling up the settings for games I have already configured. When I look at my MAME folder and check the INI files, the resolution settings (and any command line options) are indeed present in the INI file, but when I select the same game in the RES Tool the settings don't show up (instead everything is blank as though the settings don't exist).
« Last Edit: March 29, 2005, 11:59:19 pm by breaker »
Breaker
Re: AVGA MAME Resolution Tool problem
« Reply #1 on: March 30, 2005, 05:27:20 pm »
Hi all,
I've been tinkering with the AVGA Res tool the last couple of days but haven't had much luck. I suspect MinWah will have to address things when he returns in a few weeks.
In the meantime,  to verify that I understand how the AVGA Res Tool is supposed to work, can  I ask BYOACers this question:
1)  is the AVGA Res Tool supposed to read-in existing INI settings when it starts up and have those settings available for edit by clicking on a game title? (after you've initially generated the INIs of courses)
Thanks,
Breaker.
