Author Topic: loosing sync when switching resolution  (Read 1912 times)
pacman
  • Last login:October 01, 2007, 09:51:35 am
« on: March 25, 2005, 03:40:09 am »
As per topic my HANTAREX MTC 9110 always loose V-sync when switching between games using different resolutions. ::) so that I need to slight adjust the pot.Do you know what this could be ? ???
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
Re: loosing sync when switching resolution
« Reply #1 on: March 25, 2005, 10:37:08 am »
I had this problem on my MTC 9000 and I can't remember how I fixed it.
What resolution are you using?
I think you need to configure the mame.ini for your set up.
pacman
« Reply #2 on: March 25, 2005, 06:43:22 pm »
I am using 640x240 for the desktop (still have to install Mamewah and using MAME32 temporaly);It looks like the V-pot is very sensible...if I just push gently on it then it goes rolling slowly. Vertical games are OK but for many Horizontal game I need to adjust the V-sync ::)
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #3 on: March 26, 2005, 12:56:33 pm »
Try 640x288 interlaced (I think that's the one)
pacman
« Reply #4 on: May 04, 2005, 10:50:32 am »
Well now I am using Mamewah in 640x480 and nothing changed. All my vertical games works fine but many horizontal games require a pot adjustment (I believe many with 240 H lines). I set up INI files with AVRES utility... ???
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #5 on: May 04, 2005, 11:48:58 am »
Be sure to remove all non 60hz modes when using the util.
Later,
dabone
pacman
« Reply #6 on: May 06, 2005, 09:04:58 am »
Is there any chance to have the correct INI file to be used with AVRES ? ..I mean the one with the best resolution that the utility should pick up for each game?  ???
