Author Topic: Making your own gas/brake analog pedal  (Read 2638 times)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« on: March 22, 2005, 09:33:26 am »
How would one make their own gas or brake pedal?
nipsmg
  • Last login:November 22, 2025, 09:01:17 am
  • ROONEY!! ERRGH!!
    • Arcadia
Re: Making your own gas/brake analog pedal
« Reply #1 on: March 22, 2005, 09:44:58 am »
With pots.
Edit (I've searched for this also, I'm definitely interested in hearing the answer).
« Last Edit: March 22, 2005, 10:09:35 am by nipsmg »
SirPoonga
  • Puck'em Up
« Reply #2 on: March 22, 2005, 10:46:40 am »
I'm interested in a couple of reasons.
« Last Edit: March 22, 2005, 10:48:33 am by SirPoonga »
menace
« Reply #3 on: March 22, 2005, 10:52:22 am »
http://www.gunpowder.freeserve.co.uk/wheels/buildmain.htm
best write up i've come across--(your mileage may vary)  8)
GGKoul
  • Cheesecake Apprentice
  • Last login:May 26, 2024, 02:06:23 am
  • I was once a big man!! -4700 posts later...
« Reply #4 on: March 22, 2005, 10:55:10 am »
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: March 22, 2005, 12:16:34 pm »
hbm*rais
  • Last login:September 03, 2010, 08:43:44 pm
  • Relaxen und watchen das blinkenlichten!
« Reply #6 on: March 22, 2005, 02:06:20 pm »
Lot's of information on building pedals, wheels and whole cockpits on this forum:
http://forum.rscnet.org/forumdisplay.php?f=186
But the two links mentioned before should cover most of what you need.
Beware, thou, as you mentioned guitars, there is two kinds of pots: logarithmic one (used for audio applications) and linear ones (the ones you need).
hatrick
  • Last login:January 23, 2020, 12:47:20 pm
  • Big Brother is Watching You!
« Reply #7 on: March 22, 2005, 03:18:39 pm »
Lilwolf
« Reply #8 on: March 22, 2005, 03:21:42 pm »
quick note... both of those will only work well with a sit down cabinet.  You really want to look at a thinner one.
I JUST won a 2 pedal set on ebay (because I have one pole position pedal now, and wanted a second because of two steering wheels).
Anyway, I will have one up for sale if the other two work out in a few weeks.  I think I got it for 10+shipping...
Voodooray
  • Last login:July 24, 2006, 04:52:41 am
  • Load ya swine!!!!!
« Reply #9 on: March 23, 2005, 05:55:43 am »
I got these for free when i bought a steering wheel asembly and turbo gear shift for
Voodoo Ray.
88 Acid Revival, Safe!
menace
« Reply #10 on: March 23, 2005, 08:36:42 am »
Menace, what did you use?
I based my design on the first link with modifications becuase I wanted 360 wheels not 270--so i kept the double row of bearings (used roller blade wheel bearing and not pillow block ones) and instead of the gear at the end, I have an encoder wheel which I based off of one of the templates over in the build your own spinner section.  I also used a long carriage bolt (5/16") as it made mounting everything so much easier--just bolt it together and call it done.  The head of the bolt is hidden under the plastic cap on the wheel.
For pedals I used pc pedals--cheaper, easy to find and already wired.
Chris
    • Chris's MAME Cabinet
« Reply #11 on: March 23, 2005, 12:06:37 pm »
When you're standing up, though, you're putting pressure on the plastic pedals in a way they weren't designed to take.  My plastic PC pedals always feel like they're going to break.
I was thinking of building pedals using heavy-duty gate hinges.  They'll look awful, but they'll work well from a standing perspective.
--Chris
--Chris
menace
« Reply #12 on: March 24, 2005, 06:47:56 am »
I'm perfectly happy with the pc pedals I'm using (dexxxa) and they are more than sturdy enough to withstand significant abuse (I've had some friends kids over to "playtest" the machine--amazing what the rugrats can destroy that you wouldn't even think about...
SirPoonga
  • Puck'em Up
« Reply #13 on: March 24, 2005, 01:12:06 pm »
Like I said, I've been searching guitar volume pedal sites too.
http://www.geocities.com/stompboxworktop/rocker4.jpg
Just need to put a sping on one side of the pedal for arcade.
