Author Topic: 27" S-Vid TV that powers up to S-vid input  (Read 4362 times)
Jungle
  • Last login:March 05, 2006, 08:38:19 pm
  • I want to Build My Own Arcade Controls!!
« on: November 11, 2002, 01:44:52 pm »
I am getting ready to upgrade from my 19" TV w/composite vid-in to a 27" TV w/S-vid in.
I need to find a TV that has two main features:
   * turns off when power is removed (not that hard to find!) and turns back on when power is restored
   * returns to S-video input on power-up
Does anyone have any recommendations?  I'd like to stay away from flat screen models as the Happ Monitor Bezel is designed for curved front screens.
Thanks,
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
Re:27" S-Vid TV that powers up to S-vid input
« Reply #1 on: November 11, 2002, 02:47:10 pm »
I have a 24" APEX (flat screen & S-video) that does neither of these things.  I wish it did.  I can't speak of 27" models but be leery of APEXs, if those are the required features.
It was a promo from a local electronics store for US$150 so I put up with having to turn it on and switching to S-video with the remote.  It does let me leave the machine on without burning-in the screen.
Ghoul
  • Last login:September 15, 2004, 08:59:06 am
  • Karate Fish Master
« Reply #2 on: November 11, 2002, 05:48:41 pm »
A good way to do this at best buy for any tv:
Find the setting that makes the tv display s-video (usually this is turning the tv to video mode, there may be more than one video mode if the tv has several inputs but it doesn't really matter which one you use).
Look under the shelf where the tv is and yank out the power cord. Wait a few seconds and then plug it back in. If it powers itself on and back to the video mode, then you're set.
    • GroovyGameGear.com
« Reply #3 on: November 12, 2002, 11:01:17 am »
This is a good tip.
But you might want to wait for more than a few seconds.   My 27" Sanyo will remember that it was on S-video, but doesn't turn itself back on af ter you pull the plug.  However, it WILL power back on if you re-apply power within 20 seconds or so!
So to be sure, give it a good minute or more before re-applying power, as every set will be be different in respect to how long it takes for the power to wind down and lose it's current settings.
On the other hand, it's not that big a deal to point the remote at the bezel and turn on the screen (if you left a tiny clear spot for the receiver.)
This prevents burn-in, as mentioned by a previous poster.  You can also hide the remote to keep unwanted "guests" from screwing around with it without your permission.
There is also one more cool possibility with sets that don't turn on automatically:
With a little work, you can devise a circuit that will use a timer and a relay to "press" the power button after a pre-determined amount of time.  What good is this you ask?  Well, some people get disgusted by the thought of seeing windows booting on their arcade machine.  Just program the circuit with a suitable delay, and the first screen you see will be your frontend (or whatever game you may have autobooting).  ;)
« Last Edit: November 13, 2002, 01:48:18 pm by RandyT »
lusid
  • Last login:January 04, 2016, 11:01:53 am
    • LuSiD's Arcade Flashback
« Reply #4 on: November 20, 2002, 03:09:22 am »
On the first mame cab I worked on, we soldered a wire in to short the power button on the tv's front panel.  After that it would power itself up when you plugged it in.
C - - - - - o
