Author Topic: MAME question ??????  (Read 1725 times)
sean2276
  • Last login:June 22, 2005, 10:47:04 pm
  • SHAKEN NOT STIRRED
« on: March 19, 2005, 12:58:35 am »
I have an empty arcade cabinet, and I want to hook up all my consoles inside
ps2
xbox
dreamcast
n64
snes
nes
they will be connected to a tv with a game selector (pic)
the problem is that i'm having is that I'm not sure how to connect all the controllers to one arcade control panel
Any idea's?
Don't let your meat loaf
TalkingOctopus
    • My Arcade
Re: MAME question ??????
« Reply #1 on: March 19, 2005, 02:38:17 am »
You can hack a ps controller to your arcade controls and use it along with adaptors to play ps2, xbox and dc. Then you can hack some nes and controllers to your arcade controls as well.  Only one system should be attached to the arcade controls at a time.  My solution was to use molex connectors.  When I switch systems, I have to unplug the current system and then plug the new one in.
I don't think I can recommend attaching an n64 to arcade controls.  There just aren't enough games to take advantage of the arcade controls.  I feel that they are best played on the original controller using the analog stick.
sean2276
« Reply #2 on: March 19, 2005, 10:01:07 am »
I want to hook them up all at once, and only have to change the selctor.
any other ideas????
itismejs
  • Last login:February 29, 2012, 05:25:43 pm
« Reply #3 on: March 19, 2005, 01:12:28 pm »
nes and snes can be emulated from the DC. lik-sang should sell ps2 adaptors for xbox and DC.
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #4 on: March 19, 2005, 02:33:58 pm »
can be emulated on xbox.. in fact, you can cut out everything up to Dreamcast, because xbox can emulate it.. Oi!
itismejs
« Reply #5 on: March 19, 2005, 02:48:38 pm »
Thats if he wants to mod the xbox... a possibilty but might me cheaper to just use the dreamcast.
sean2276
« Reply #6 on: March 19, 2005, 08:26:01 pm »
I plan on getting my xbox modded
daywane
  • Last login:August 29, 2025, 03:53:34 pm
  • GRRRR!
« Reply #7 on: March 20, 2005, 07:04:36 am »
as far as I know the super nintendo emu on dreamcast is not that good.
I loike the Nes emu and the Sega master but thats about it on the dream cast.
