Author Topic: Can I reuse this chassis?  (Read 1658 times)
Humanoid
  • Last login:February 12, 2010, 12:55:13 am
  • I want to Build My Own Arcade Controls!!
« on: March 15, 2005, 11:49:13 am »
So I just completed my custom cocktail cabinet last night; for the grand finale I was going to put the monitor in for the last time.  While placing the monitor into its custom mount, WWUUUSHHH!  The sound of air rushing into a broken tube! :'(  I spent the last 3 months building my cabinet around a 27" Gateway Destination monitor.  So the tube is obviously trash now, but can I reuse the chassis on a different tube?  The monitor was an 800x600 progressive (i.e. computer monitor) set with a lone vga input.  If you reply it will lift my spirits as I dwell on my loss.
My long desired cocktail is moments from completion, I just have to find those moments somewhere!
Ken Layton
  • Guru
  • Technician
Re: Can I reuse this chassis?
« Reply #1 on: March 15, 2005, 12:06:59 pm »
I wouldn't know on computer monitors. My experience is with commercial arcade monitors.
menace
« Reply #2 on: March 15, 2005, 12:11:05 pm »
yeah but good luck finding a donor tube--when pc monitors stop working most people chuck them and you'll need to find one compatible with that chassis (same model).  I guess at this point measure the vertical and horizontal ohms of the yoke and make a note of the number of pins in the necktube--who knows you might get lucky.
MonitorGuru
  • Last login:October 05, 2005, 11:29:43 pm
« Reply #3 on: March 15, 2005, 12:14:40 pm »
If you found an idential tube then yes. Computer tubes arn't as interchangable as TV's/arcade monitors. Wide range of resolutions, phosphors, etc..
Plus, it probably had a significantly advance active yoke---in other words, rather than a simple wire wound yoke, it had PC boards with mini electromagnets and mutiple things wrapped around the yoke to allow you to do all the neat on-screen convergence, rotation, geometry control.
MonitorGuru
« Reply #4 on: March 15, 2005, 12:18:22 pm »
Wade
  • Last login:December 01, 2025, 08:21:17 am
  • 80's Child
    • Wade's Gameroom
« Reply #5 on: March 15, 2005, 04:19:58 pm »
IIRC the Gateway destination monitors are really just TV's with a VGA input on them.  They definitely don't have the image quality of a real PC monitor.  I think they are likely more related to a TV than a PC monitor.  It would be worth investigating the possibility of a tube swap, IMO.
Wade
Humanoid
« Reply #6 on: March 15, 2005, 08:21:46 pm »
Yeah, thats what I loved about the monitor.  It looked like tv, but with better color/saturation and no annoying tv whine and the ability to actually read text at 800X600.
