Author Topic: Starwars gears?  (Read 1854 times)
Lilwolf
Starwars gears?
« on: March 15, 2005, 09:43:34 am »
Anyone know if you can order the starwars gears anywhere?  I'm looking for the ones inside for up/down.
I have a Hydra control panel, but it has a scaled Y axis.  but it seems to have the exact same mounting bracket for the y Pot.  So I should be able to replace the current mechanism with some real starwars ones and have it work.
rdagger
Re: Starwars gears?
« Reply #1 on: March 15, 2005, 11:49:25 am »
Here's an auction on Ebay.
If someone wants to lend me some yoke gears, I could try to cast copies for you in Alumilite.
Lilwolf
Re: Starwars gears?
« Reply #2 on: March 15, 2005, 08:09:57 pm »
I've been watching that one.  I didn't want to spend that much for a set of gears (especially since they might not be in good shape) but am considering it.
Anyone out there know the size / tooth count on each?  I saw the sizes in another thread (old thread) but it was for the back two... and I don't need those.
GGKoul
  • Cheesecake Apprentice
  • Last login:May 26, 2024, 02:06:23 am
  • I was once a big man!! -4700 posts later...
Re: Starwars gears?
« Reply #3 on: March 15, 2005, 08:43:46 pm »
That'll auction will sell for over $50+...
You can check here for gears.... www.mcmaster.com
usedelectronics
  • Last login:January 06, 2019, 02:57:37 am
Re: Starwars gears?
« Reply #4 on: March 15, 2005, 08:50:52 pm »
I have a few sets of NOS gears available. :)
Rocky
  • Last login:December 30, 2009, 12:38:41 pm
  • I want to finish my cab before I retire!!
Re: Starwars gears?
« Reply #5 on: March 15, 2005, 10:44:49 pm »
Do a search on the klov forums.
GGKoul
Re: Starwars gears?
« Reply #6 on: March 21, 2005, 12:17:28 pm »
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=13718&item=6162558227&rd=1&ssPageName=WDVW
Here you go.. $87 for a broken Star Wars yoke.  I assume a good one will sell for $200+ now
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
Re: Starwars gears?
« Reply #7 on: March 21, 2005, 03:49:10 pm »
Hey I won that one!  I already have some original SW handles to finish it with.  Won't be too hard to make a cover plate either.  After seeing Oscar's I figured it was better to get that one cheaper if they are now going to be $2-3-4-500+, ouch.
I think someone (Oscar maybe?) had posted a part number from Mcmaster as a replacement part for the SW yoke.  It was a long time ago though.
When I get it, I can measure for you.
Next I'll be on fries, and that's when the big money starts rolling in.
2600
Re: Starwars gears?
« Reply #8 on: March 21, 2005, 04:21:17 pm »
From some info I have:
wmberg.com
These are aluminum replacements:
The two small gears, forget which one goes where.
part #p24a66-14
part #f24d5-28
The big one's are trickier.  Everyone say you just need to ask them for this part# and to drill a 3/4" bore.  Only problem I believe is that is the diameter of the hub, so you need bigger hub too.
part #P24A68-60
I think this is a delrin plastic version of one of the 28-tooth one.
part #P24D28X-28
Let us know how it goes. I know some people have gotten them, but feedback is always good.
Edit:  Anyone got an extra springs, hardware stores around here suck?
« Last Edit: March 21, 2005, 04:24:38 pm by 2600 »
GGKoul
Re: Starwars gears?
« Reply #9 on: March 21, 2005, 04:40:37 pm »
