Author Topic: Versa-Ball with a J-Stick?  (Read 1083 times)
NoBonus
  • Last login:January 07, 2007, 06:48:58 pm
  • "Now that's a fine example of California's Gold"
evlbeaver
  • Last login:February 13, 2011, 10:42:53 pm
Re: Versa-Ball with a J-Stick?
« Reply #1 on: March 14, 2005, 11:15:18 pm »
I don't think it would work without machining.  Isn't the J-Stick threaded on the bottom and smaller in diameter?
NoBonus
« Reply #2 on: March 14, 2005, 11:42:01 pm »
I am unsure of the diameter. I know the Versa Ball is 10mm, but I do not know the diameter of the J-Stick.  The thread on the bottom of the J-Stick should be replicated with the multiple threads on the Versa Ball.
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
« Reply #3 on: March 14, 2005, 11:53:07 pm »
It might fit an ultimarc T-Stick.  It is supposed to be able to fit a Happ competition and I was able to get a shaft from a competition to fit an Ultimarc T-Stick.  I don't think it would fit a J-Stick though, but I'm not sure.
NoBonus
« Reply #4 on: March 14, 2005, 11:58:36 pm »
Is there an easy way to accurately measure diameter?
« Last Edit: March 15, 2005, 12:00:36 am by NoBonus »
NoBonus
« Reply #5 on: March 15, 2005, 12:03:36 am »
With a quick measure, I get 12mm, but that may not be accurate (I eyeballed it).
