Author Topic: ** WIP ** Beep!Beep! ** RoadRunner **  (Read 2527 times)
ripzone
  • Last login:February 23, 2006, 02:28:01 pm
  • Pac-Mini coming soon...
    • RiP's M.A.M.E. Arcade Cabinet
« on: March 13, 2005, 05:26:33 pm »
Hey, I just started yesterday learning Illustrator.
To start I picked up some Unvectorized marquee from the AAL and started vectorizing it.
Here's what I've got after a few hours.
What do you think?
Original Marquee
Vectorized Marquee (Unfinished)
« Last Edit: March 14, 2005, 03:22:21 pm by ripzone »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Beep. Beep. My 1st Vectorization.
« Reply #1 on: March 14, 2005, 12:21:18 am »
Did you shrink down the original marquee, or is that the size you're working from? Honestly, it doesn't look too good right now. Road Runner looks like... well, let's just say that Warner Bros. wouldn't approve that rendition of him  ;D
NO MORE!!
Bones
  • [Moderator]
« Reply #2 on: March 14, 2005, 02:44:51 am »
For only a couple of hours learning illustrator I think it's pretty damn good!
mahuti
« Reply #3 on: March 14, 2005, 05:17:40 am »
That's actually very close to the original Rayb.
mahuti
« Reply #4 on: March 14, 2005, 05:18:08 am »
Whether or not they approved of the original... that' I can't say.
ripzone
« Reply #5 on: March 14, 2005, 01:06:47 pm »
Anyone knows the two fonts used in the marquee?
The one that says "Beep! Beep!" and the other one "Road Runner"?
Thanks in advance.
mahuti
« Reply #6 on: March 14, 2005, 01:07:28 pm »
Custom
ripzone
« Reply #7 on: March 14, 2005, 02:11:20 pm »
Here is my progress:
Click below to go bigger:
http://img118.exs.cx/img118/7416/byoac8vw.jpg
How do I cut that part of the image?
Thanks AI leets.  ;D ;D
ripzone
Re: ** WIP ** Beep!Beep! ** RoadRunner **
« Reply #8 on: March 14, 2005, 04:38:25 pm »
mahuti, any tip?
RayB
  • There's my post
    • RayB.com
« Reply #9 on: March 14, 2005, 09:51:38 pm »
Oh god the original IS like that. OK good job  ::)
NO MORE!!
Snoogans
  • Last login:January 21, 2011, 06:26:54 pm
« Reply #10 on: March 14, 2005, 10:18:54 pm »
Use the pathfinder.  (Window/pathfinder)  Make another shape that's going to be where the cut is, a marquee will do, and then select both shapes.  Play around with the different modes until you get what you're looking for.  The problem is, if you used a stroke around the original shape.  Once you make the cut the stroke will be across the top also.  So, before you use the pathfinder, turn the stroke into its own shape.  Object/path/outline stroke.  Hope that helps.
