Author Topic: Where can I find cotnrol panel temlates?  (Read 2932 times)
Chameleon
  • Last login:November 05, 2002, 08:20:29 pm
« on: November 06, 2002, 08:41:25 am »
Hi my firends
Where can I find cotnrol panel temlates. Please give me a adress  ???
Chameleon
Re:Where can I find cotnrol panel temlates?
« Reply #1 on: November 06, 2002, 08:49:37 am »
Sorry,
I posted this before read the old posts. I found my answer
liche
  • Last login:November 13, 2007, 08:05:18 am
  • This is my BOOMSTICK!
« Reply #2 on: November 06, 2002, 03:51:44 pm »
You can always design them yourself. They aren't very difficult to do.
Basically you need a cad package capable of printing 1:1.  I use AutoCad 2002 Professional or AutoCad v14.
Basically draw your control panel to scale - basically just a rectangle.
Second, using the dimensions from the pushbutton / joystick's manufacturers, make little 1:1 pushbuttons.
Basically only the cut-out and a center mark for the cut-out is necessary, but you should put the pushbutton in there as well so you can get an idea of what the actual size is when arranging your buttons etc...
Thirdly, if you have any wood pieces or other parts underneath your control panel (such as my TAITO panel), make sure you mark "keep-out" zones on your panel outline so you don't place buttons there.
Next, decide how many buttons you want to use, and then just plop them down and arrange them how you like.
When you are finished, you can just print out plots of your control panel at 1:1 scale and mark your control panel for machining from there.
Very easy and very accurate.
AutoCad also lets you import graphics files (such as control overlays) so you can see exactly how your panel will look beforehand.
Perhaps if other people have access to AutoCad, we could start making standard arcade buttons / joystick cad symbols to use for this type of control template design process.
SNAAAKE
  • -Banned-
Darkstalker
  • Last login:June 27, 2010, 12:55:36 am
  • A legend in my spare time...
« Reply #4 on: November 08, 2002, 02:25:00 am »
Visio is a much cheaper way to go, and there is a template link on the main site (http://www.arcadecontrols.speedhost.com/arcade_puttogether.shtml#Templates) that I used for my planning.  It's a lot easier to work with than AutoCAD if you've never used it before (Although 2000 is much easier than r8..hehe).  Almost anything will work, even MS Word if your really pressed for a program to make the printout.
Look to other templates for ideas and even post on the board for advice, but make sure it's the way YOU want it because we're not going to be the ones using it, you are ;)
Still in the collecting parts and ideas phase of cabinet building.
