December 18, 2025, 10:20:44 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Monitor/Video Forum
WG K7000
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: WG K7000 (Read 6380 times)
nitebreed
Trade Count:
0
Full Member
Offline
Last login:February 13, 2006, 09:35:24 pm
WG K7000
on:
March 13, 2005, 01:00:57 pm »
The top inch or so pulls to the left and there seems that there is less signal strength there as well.
I have installed a cap kit, also replaced R70,R71,C30,C31 Here are a few pics
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Last login:October 12, 2021, 12:25:59 am
Technician
Re: WG K7000
Reply #1 on:
March 13, 2005, 01:33:47 pm »
Try adjusting the 50/60 hz pot and maybe turn the contrast down a bit. Also check the horiz hold adjustment may be a tad too far one way or the other.
Logged
Will
Trade Count:
0
Full Member
Offline
Last login:April 08, 2012, 03:32:27 am
Finished Lurking.....
Re: WG K7000
Reply #2 on:
March 14, 2005, 03:30:09 pm »
That looks exactly like how my monitor used to display.Cap kit did not solve problem and I had it completly serviced by a local arcade monitor wizard.He replace fuses redid a bunch of the wiring to neckboard and resolder a ton of bad solder points.The bend is now gone,wish I could be more helpful but the cap kit didnt fix my issues.
Logged
dabone
Trade Count:
0
Full Member
Offline
Last login:July 15, 2025, 08:32:17 pm
Time to work...
Re: WG K7000
Reply #3 on:
March 14, 2005, 04:19:51 pm »
I noticed you are using advmame.
Have you tried your monitor with a game board or a arcadevga card???
I've had a perfectly good monitor display like that with advmame, and had to change video cards to get a good pic.
Later,
dabone
Logged
nitebreed
Trade Count:
0
Full Member
Offline
Re: WG K7000
Reply #4 on:
March 14, 2005, 05:47:41 pm »
yeah I'm using advmame I also get the same thing in windows on that monitor i am using matrox video card and i also have a arcadevga card and from what i remember that one did the same thing ...It's kinda weird because only on that one inch strip when i go to try to square the top with the other 80 percent that is all ready straight it will come over but the bottom of that one inch strip that is bad want line up and vice,vers
Logged
Will
Trade Count:
0
Full Member
Offline
Re: WG K7000
Reply #5 on:
March 14, 2005, 07:24:19 pm »
What program are you using for that test screen you have an color convergance?Is this a menu from the monitor or this a program run in windos.Would love to tweak my monitor a little more.
Logged
nitebreed
Trade Count:
0
Full Member
Offline
Re: WG K7000
Reply #6 on:
March 15, 2005, 07:15:47 pm »
the software is advv or advcfg......
Logged
nitebreed
Trade Count:
0
Full Member
Offline
Re: WG K7000
Reply #7 on:
March 17, 2005, 08:33:37 pm »
Here Is What Wells Gardner Relpied, Will try and see if it corrects the problem will order parts and let the forum know if that works
thanks for getting that info for me. now from past experience that problem is usually caused by a cap in the horiz phase circuit. majority of the time it was capc28 that is parallel to r69. if that doesn't correct the problem then change c29, c30 or c31. and as a last resort change ic2. so give that a try and keep me informed on your progress.
Logged
arcadepcnut
Trade Count:
+2
Full Member
Offline
Last login:August 15, 2019, 12:03:07 pm
Warhammer 40K, you should try it.
Re: WG K7000
Reply #8 on:
March 22, 2005, 12:26:32 am »
my monitor had the exact same problem just at the bottom of the screen instead of the top. A slight tweak to the 50/60hz pot fixed it.
Logged
nitebreed
Trade Count:
0
Full Member
Offline
Re: WG K7000
Reply #9 on:
March 26, 2005, 02:23:18 pm »
The 50-60hz pot only controls the vertical on the picture .....This is a Horzontal problem....I have ordered the ic2 chip to replace ...having trouble finding c28 which is
5pf 20% 2kv npo ceramic capacitor any one know where i can get a few....
?and a good place to purchase components for boards...
by the way if anyone is replacing ic2 bob roberts has them for 6 buck
happs have them for 12 bucks plus 10 buck for orders under 25.00....
Logged
DaveJ-UK
Trade Count:
0
Full Member
Offline
Last login:January 11, 2025, 04:20:37 am
Dirty Dawg
Re: WG K7000
Reply #10 on:
March 26, 2005, 04:04:41 pm »
These guys stock a lot of hard to find bits n pieces;
http://uk.farnell.com/jsp/home/homepage.jsp
Someone here gave me that link last week but I'm yet to order anything.
Logged
nitebreed
Trade Count:
0
Full Member
Offline
Re: WG K7000
Reply #11 on:
March 26, 2005, 07:38:21 pm »
nope not there ......but thanks......this going to be a hard one to find......
Logged
DaveJ-UK
Trade Count:
0
Full Member
Offline
Dirty Dawg
Re: WG K7000
Reply #12 on:
March 27, 2005, 02:33:29 pm »
http://www.maplin.co.uk
(unlikely to have anything that specialised but worth mentioning)
http://www.rscomponents.com/
Logged
APFelon
Trade Count:
+1
Full Member
Offline
Last login:July 04, 2024, 08:51:53 pm
Re: WG K7000
Reply #13 on:
March 27, 2005, 05:05:34 pm »
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=307534&Row=395236&Site=US
Is that the one? I assumed 2kv is 25 volts...?
Otherwise, just go to
www.digikey.com
and use their online parts finder.
APf
Logged
nitebreed
Trade Count:
0
Full Member
Offline
Re: WG K7000
Reply #14 on:
April 19, 2005, 03:24:20 pm »
don't think it is 25 volts. Kilo means 1000 so 2kv would be 2000 volts
Still no luck on finding one though. Seem like someone would have some . Is pf value and uf value the same and if so what is the conversion since i need a 5pf 2kv ceramic capacitor what would the 5pf be in uf standards. Another question does anyone know if u can use a different value in that spot C28...Some Please help me find this cap....thanks to all that have helped thus far.....By the way did get the ic2 chip and installed and it help a little not much at all though.......
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
WG K7000
