Author Topic: MameWAH vs. MAME 32: clarity, resolution  (Read 1700 times)
JCKnife
  • Last login:November 04, 2008, 09:41:57 pm
« on: March 12, 2005, 12:55:17 pm »
I'm using and AVGA card on a WG D-9200 monitor.
When running MAME32, every game is CRYSTAL CLEAR, bright and beautiful.
Out of MameWAH, most games look blurry, fuzzy, even dim.
I used the AVGA resolution tool to generate INI files for all the games.
Does MAME32 have some other option or filter setting that is making the games look SO much better?
In Mamewah, it almost looks like an attemt at anti-alaising or something. It's on my nerves. Any help appreciated.
(Otherwise I'm loving Mamewah).
APFelon
  • Last login:July 04, 2024, 08:51:53 pm
Re: MameWAH vs. MAME 32: clarity, resolution
« Reply #1 on: March 12, 2005, 02:12:00 pm »
It isn't MAMEWAH. It's MAME itself. Check the INI, disable stretching, etc. There are a few FAQs around that'll get you where you need to be.
APf
JCKnife
« Reply #2 on: March 12, 2005, 08:54:46 pm »
If someone can point out a FAQ that covers this I'll gladly read it. I thought I'd seen them all...
APFelon
« Reply #3 on: March 13, 2005, 12:48:20 am »
Well, let me simply post my MAME INI file. Compare these video options to yours; I'll wager that the problem will be pretty evident. I'll look around for the FAQ just to make sure. Good luck!
### Windows video options ###
autoframeskip           1
frameskip               0
waitvsync               0
triplebuffer            0
window                  0
ddraw                   1
direct3d                0
hwstretch               0
cleanstretch            auto
resolution              auto
refresh                 0
scanlines               0
switchres               1
switchbpp               1
maximize                1
keepaspect              1
matchrefresh            0
syncrefresh             0
throttle                1
full_screen_brightness   0.000000
frames_to_run           0
effect                  sharp
screen_aspect           4:3
### Windows Direct3D 2D video options ###
zoom                    2
d3dtexmanage            1
d3dfilter               1
d3dfeedback             0
d3dscan                 100
d3deffectrotate         1
d3dprescale             auto
d3deffect               none
# d3dcustom             <NULL> (not set)
# d3dexpert             <NULL> (not set)
JCKnife
« Reply #4 on: March 13, 2005, 09:16:10 am »
effect=sharp was one difference and it helped a little bit, but the games are still blurry. For example, Robotron launched out of MAMEwah is clear in the center of the screen, but has vertical bars of blurry area one-third in from each side.
If I drop out of Mamewah and run it from the command line, it's drop-dead perfect.
EDIT:
Duh! I had dorked around with my mame.ini file in Mamewah. It's fine now. Sorry, thanks!!!
« Last Edit: March 13, 2005, 09:31:37 am by JCKnife »
teetu
  • Last login:January 17, 2016, 03:29:31 pm
« Reply #5 on: March 16, 2005, 01:14:56 am »
thanks for the ini, just what I needed.
-edit-  i figured out i needed to turn on triple buffer to eliminate "tearing"
Is it possible to turn off slowdown in mame?  In nebula it's easy to do the cpu overclock thing and not have any slowdown.
I guess if I could get nebula to display properly I would just use that, but it's giving the "blurry" picture (interlaced I think) and none of the resolution filters looks good.
I can't beleive I actually thought about using a regular TV with svideo instead of a real arcade monitor...
« Last Edit: March 16, 2005, 02:58:23 am by teetu »
