Author Topic: updating MAMEWAh question  (Read 1201 times)
killbill
  • Last login:March 03, 2026, 04:31:25 pm
  • When I die, I want to go to arcade heaven!
« on: March 11, 2005, 12:58:18 am »
hi Guys,
I have a really quick question.
I am currently using a pretty old version of Mamewah, like 1.3 or something like that.
If i want to update to the current 1.6, can I just change out the mamewah.exe file or do i need to update the whole file structure to 1.6?
Thanks,
Jason
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
Re: updating MAMEWAh question
« Reply #1 on: March 11, 2005, 03:37:08 am »
i did this upgrade a few days ago.
start off by putting the new mamewah in a different directory and copy over stuff one at a time.
I was able to copy over my files directory, and my layouts directory.
I copied over my ini directory but then I had to go grab a newer version for the ones that don't have a number in them. so mame.ini needed updating but not mame-0.ini. You can find already configured ini files here for all sorts of emulators:
http://home.comcast.net/~cpviewer/downloads.htm
Make sure to fix the file paths and screensaver settings and what not.
mamewah.ini will need updating too. But most of these updates are pretty easy to copy and paste your old settings into the new files.
Once I updated the ini files all my old lists worked great without needing to be regenerated.
Joseph Elwell.
