Author Topic: MAME Output Control  (Read 2926 times)
liche
  • Last login:November 13, 2007, 08:05:18 am
  • This is my BOOMSTICK!
MAME Output Control
« on: November 04, 2002, 10:01:22 am »
Does the code in MAME support output control either via the parallel port, serial port, etc... to provide output signals which could be used to trigger the Player 1 / Player 2 pushbutton illumination when credits are issued etc....????
For example, put in one credit, and the player 1 pushbutton will flash / light-up etc...
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:MAME Output Control
« Reply #1 on: November 04, 2002, 10:44:20 am »
I'm not going to say it doesn't or couldn't with a little hacking... but SOME games in MAME use the keyboard lights (num lock caps lock etc) to indicate sorta what you are talking about... Especially the old Atari and atari vector games.
If you use an IPAC, there's a harness available to do just that... light some led's for num/caps lock...   or you can run extensions from a keyboard for those leds as well...
*shrug*
hope that helps...
rampy
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: November 04, 2002, 10:56:46 am »
mame uses the keyboard lights.
