Author Topic: I found a good joystick for T2  (Read 1351 times)
markrvp
  • NFL Expert
« on: March 08, 2005, 03:37:30 pm »
I originally bought this logitech Extreme 3D Pro for playing Afterburner II.  After studying Terminator 2 a little bit I discovered that this joystick can mimick the original T2 analog gun base pretty well.  Remember, these guns rotated left and right and tilted back and forth.
The flightstick has not only X and Y axis tilts but also Z axis rotation.  You can twist the handle left and right.  In T2, hit TAB to set up the controls.  By using Z axis rotation for left and right movement and the Y axis movement for up and down, I get really great (and very fast) response.
These things are $30 at Wal-Mart.  USB hotswappable is nice and you can use two at the same time.
Hoagie_one
  • Um....whats a cabinet
Re: I found a good joystick for T2
« Reply #1 on: March 08, 2005, 03:45:17 pm »
just have to mount a gun to em.
How many mame games used positional guns?
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #2 on: March 08, 2005, 03:47:12 pm »
Nice find. T2 guns are plentiful at auctions and distro houses. I'm sure it would only take about an hour to mount an old gun to this joystick. If I were still living in the states, I'd pick one up.
Signature tags are dumb.
ErikRuud
« Reply #3 on: March 08, 2005, 07:27:07 pm »
These are not the only analog sticks with z-axis rotation.
I have two others.  One is a Microsoft Sidewinder 3D Pro(Older, Gameport only) and the other is a Microsoft Sidewinder Precision Pro(Newer, USB or Gameport).
American Laser Games Wrapper
O2em Rom Utility
1UP
  • Token Junkie
    • 1UPArcade
« Reply #4 on: March 09, 2005, 04:04:06 am »
I was originally thinking of using a 3-axis joystick before I found two T2 guns on ebay and decided to use the real thing.  :)
I think you might want to try to lock the x axis if you're planning to mount guns.  I think the shells of a Happ submachine lightgun would make a pretty good topper.  The added benefit is that they already have mounting points for switches.
My other job...
Xiaou2
  • Last login:Today at 01:03:15 am
  • NOM NOM NOM
« Reply #5 on: March 09, 2005, 04:23:47 am »
 well, just remember that these joys are not built to handle extreme stress - esp on the z rotation.
 Popping a gun on the shaft would add weight to it, and also, would provide extra leverage.  (like a 't'  wrench)    These factors may lead to ripping the mechanism completely appart with a single excited left to right swing.
 i had a simular problem with the first analog joy i tried for a sinistar mod.  The rubber x i made was too strong for the plastic joints, and ripped it appart.   Tried strong cableties arrond the assembly - but still not good enough to handle the extreme stresses.
