Author Topic: ArcadePC control panel conversion  (Read 3596 times)
Katana Man
  • Last login:September 22, 2024, 12:10:44 pm
« on: March 08, 2005, 02:42:59 pm »
Hi fellas,
« Last Edit: March 18, 2005, 11:35:14 am by Katana Man »
GGKoul
  • Cheesecake Apprentice
  • Last login:May 26, 2024, 02:06:23 am
  • I was once a big man!! -4700 posts later...
Re: ArcadePC control panel conversion - need your advice.
« Reply #1 on: March 08, 2005, 07:55:13 pm »
It probably would have been easier to make a new 4 player CP that was a custom fit with your cab instead of ordering one from Slik-Stik then modifing your cabinet to get it to fit...
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #2 on: March 08, 2005, 08:31:20 pm »
For a cut of that size, I might use a good crosscut (e.g. hand) saw.
Working: Not Enough
Projects: Too Many
Progress: None
Katana Man
« Reply #3 on: March 08, 2005, 09:31:15 pm »
Thanks GGKoul, very helpful.  The ArcadePC control panel is the proprietary one.  The SlikStik control panel is all square. The cut notch will be square as well and it will bring the control panel back 2 more inches for a more secure fit and it will bring the players closer. So this is desirable.
Anyway, back to the question at hand...  CheffoJeffo, you think I can cut a clean, straight 6" cut with a hand saw?  If my hand saw isn't perfectly 90 degrees in both directions, it will mess up the cut pretty bad.  It's kind of an important cut because the control panel will be resting up against it.  Any variation will show.
kcoleman
  • Last login:September 18, 2005, 01:29:01 pm
  • My Mame obsession is driving my wife crazy
    • My Cab Blog
« Reply #4 on: March 09, 2005, 01:27:04 am »
I'm thinking of using a jigsaw with some fine teeth to make a smoother cut, and using some sort of guide rail to prevent mistakes.
CheffoJeffo
« Reply #5 on: March 09, 2005, 07:32:01 am »
I think you can, indeed, make that cut and make it straight with a good quality, sharp, crosscut saw (e.g. don't even try it with a cheap or dull saw). You can cut slowly and make a nice clean cut (I've seen people rip 4 foot lengths using nothing but a crosscut saw).
Having said that, I can't find a flaw in kcoleman's technique, although you are going to need to get the guides secured well. As kcoleman points out, the outer edge of the vertical cut is where you need to be right on. So, if you have a problem with the inner edge, you can backcut with a coping saw to achieve that flush edge on the outside.
Cheers.
« Last Edit: March 09, 2005, 09:17:58 am by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
kcoleman
    • My Cab Blog
« Reply #6 on: March 09, 2005, 08:27:22 am »
I was also thinking that if you do mess up the cut a bit you can put some sort of trim around the new control panel.  you can get quarter round trim at home depot that they use to trim out floors when the baseboards dont cover gaps in hardwood floors or a simple small square piece of wood.  If you miter the corner and paint it black it will not look bad at all.  In fact you could probably use a half inch piece of wood that is cut to 1 inch or so width and glue or screw it in from the inside of the cabinet
Katana Man
« Reply #7 on: March 10, 2005, 12:49:40 am »
Well, I set up a guide and used a Skillsaw jigsaw.
« Last Edit: March 10, 2005, 02:40:39 pm by Katana Man »
Katana Man
« Reply #8 on: March 18, 2005, 11:36:56 am »
Well, the router is definately the right tool for the job. I also cut the slots for the t-molding as well.
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #9 on: March 18, 2005, 03:04:58 pm »
You could fix that with a belt-sander too.
-Ace-
I want my own arcade controls!
InsaneDavid
  • Last login:August 06, 2011, 02:16:33 pm
« Reply #10 on: March 19, 2005, 12:21:14 am »
-Ace-
Ah yes, the belt sander, the spiral saw's best friend.  ;D
It looks really nice, Katana Man.
Katana Man
« Reply #11 on: April 22, 2005, 12:34:22 pm »
Well, here is the final results:
More details on the project can be seen here
I'm extremely happy with the end results. The control panel is interchangeable, and it locks in like a rock! I mean no movement or noise at all. The 4 draw clamps, turnbuckles, wood guide peices, and two bolts make sure of it :)
I'm working in Photoshop to design a new marquee. Almost done with that too :)
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
« Reply #12 on: April 24, 2005, 07:53:22 pm »
I like it, the new cp makes it look much better, like a new machine. I also love the fans at the base of the cab.
Gary
  • Last login:Yesterday at 08:08:43 am
« Reply #13 on: April 26, 2005, 05:23:02 am »
Do the fans make your legs hot as you play?   :D
dweebs0r
  • Ascendo tuum!
« Reply #14 on: April 26, 2005, 06:21:41 am »
Great job!
Now just swap out the marquee with your new one and maybe put on some tasteful
side art, and swap out that monitor for a larger one, and ...
-Dweebs
« Last Edit: April 26, 2005, 06:23:16 am by dweebs0r »
