Author Topic: Question regarding Lucids Plans rev 7.  (Read 2481 times)
GodSend25
  • Last login:February 16, 2005, 03:18:04 pm
« on: November 03, 2002, 12:19:03 am »
I have all my pieces cut and am being to assemble my cab based on Lucids design (the only change I made was to widen it to 28 inches, and make the control panel a little longer).
I am having a hard time visualizing the "support mechanism" that attachs to the cabinet bottom.
The instructions say "The kick plates and lower supports create a support frame for the base of the cabinet".  I do not however see how the math equals out (in terms of the sizes of the pieces).  I understand that the front and rear base plates are the width of the cabinet.  The lower supports however are only 32.5", while the depth of the cabinet at the bottom is 38".   Does the support frame go all the way back in the caibnet (ie, is the front the cabinet really supposed to hang 6.5"'s off the base (somewhere to put your feet I guess?)
Sorry if my description is a little lacking.  If you look at the plans you should see what im talking about.  Did anyone just skip the baseplate section of the plans? (ala version 6).  Thanks guys..
Richy
  • Last login:September 15, 2004, 09:04:53 am
Re:Question regarding Lucids Plans rev 7.
« Reply #1 on: November 03, 2002, 07:21:45 am »
you put down the two pieces across the base and the other two fit in between them
Like this
eaaaaaaaaae
e                  e
e                  e
e                  e
e                  e
e                  e
eaaaaaaaaae
GodSend25
« Reply #2 on: November 03, 2002, 10:42:44 am »
Richy,
I understand that part, thanks :) .  But after that, where do the side pieces attach, by that I mean, when everything is assembled, should the "real cab" part hang over the bottom supports?
Side view
front ->       |                                  | < back of cab
Bottom ->    ----------------------------
                        |                             | <= supports?
Do you see what I am asking?  From the plans I gather that the overhang between the cab and the supports/baseplates is 6.5"'s , seems like alot dont it?
spidermonkey
  • Bombjack junkie
« Reply #3 on: November 03, 2002, 11:37:33 am »
 Godsend It does look like it would be a little tipsy-turvy. If you are looking at the plans correctly and a 6" overlap is what they are implying  then personally I would revize those measurments a little.  In my opinion that much of an overlap would make for an unstable cabinet but Im sure Lusid has built more cabs than I have. Plans aren't written in stone. If you feel more comfortable building a wider platform than do so.
S.M.
"Sinistar has bad breath"
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #4 on: November 03, 2002, 03:32:01 pm »
I haven't looked at lucids plans in a while...  but on my cabinet which is an old Taito cab... there's a simliar space where the wheels go for tipping and rolling the cabinet...
I suppose you could just  extend the bottom box if  you weren't going to install the wheels/rollers...
know what I mean??
I might be wrong, but that's what came to mind when I saw the gap you mentioned...
good luck
rampy
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #5 on: November 04, 2002, 02:22:54 pm »
Take a look at this diagram:
The side supports, cabinet bottom and baseplates all fit in between the side panels.  This does create a space under the front of the cabinet, but the sides of the cabinet prevent it from tipping.
American Laser Games Wrapper
O2em Rom Utility
Darkstalker
  • Last login:June 27, 2010, 12:55:36 am
  • A legend in my spare time...
« Reply #6 on: November 05, 2002, 05:13:12 pm »
They're called kick panels BTW.  That's so your toes have somewhere to go when your standing next to the cabinet.  Only real point in using them is to prevent shoe scuffs on the front of the cabinet.
Still in the collecting parts and ideas phase of cabinet building.
