Author Topic: MAMEWAH Ques - How do you hide multiple versions of a game?  (Read 1619 times)
j123vt_99
  • Last login:August 24, 2006, 09:41:12 am
« on: March 03, 2005, 09:09:23 pm »
I'm sure many of you guys have exprienced this. you open mamewah and you have 8 different versions of the same game (for example S.T.U.N. Runner).. In Mame32 , if you go to the game under "Working", only one instance of the game is shown. Is there a setting/option that allows this in MAMEWAH?
Pictures of my Missile Command  http://www.nimsu.com/mc/mc.html
woodywood
  • Last login:February 19, 2006, 11:03:11 am
Re: MAMEWAH Ques - How do you hide multiple versions of a game?
« Reply #1 on: March 03, 2005, 10:27:42 pm »
I am not too sure of this right now since I am not in front of mine but I believe there is a setting in the config file that says display_clone_info (0-no, 1-yes). It is in your emuname-?.ini file
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #2 on: March 04, 2005, 04:15:38 am »
I am not sure, but I used the Good Utilities to divide up the different roms.  i.e. USA, Japan, hacks, bad files etc.  I made one master folder with what I wanted, and it cut down the repeats all together.
vibez
  • Last login:February 09, 2011, 08:33:20 am
« Reply #3 on: March 04, 2005, 04:49:14 am »
generate a filtered list it mamewah selecting 'cones' and picking no
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« Reply #4 on: March 04, 2005, 02:26:01 pm »
make sure you have a catver.ini file ( http://www.mameworld.net/catlist/ ) setup in mamewah. This will help you generate filtered lists. Check the Mamewah documentation on how to get the "generate filtered list" option to show up. I think you have to create an empty file in your ini directory called mame-1.ini.
I use the mamewah interface to generate a list that:
 Includes clones only if they're better than the parent
 Removes Adult Games
 Removes Lightgun games.
 Removes Games marked as Unplayable
 Removes Quiz games that are in Chinese
 Removes Mahjong games
I also have another list that only shows Adult games. :angel:
Joseph Elwell.
j123vt_99
« Reply #5 on: March 04, 2005, 07:28:18 pm »
ok.. got the catver.ini loaded ( i think) but don;t see how to limit the list based on "type" of game
jelwell
« Reply #6 on: March 07, 2005, 02:32:34 pm »
Make sure you set the "catver_ini_file" key in your mame.ini in the ini folder of mamewah.
Then create a blank ini file in that directory. Called "mame-1.ini" if it's not already there. Then in mamewah select that list (it'll probably be blank). *YOU CANNOT GENERATE CUSTOM LISTS OVER YOUR MAIN LIST* so you have to change lists first.
Then in "Generate Filtered List" there should be an option to filter based on category.
Joseph Elwell.
