Author Topic: My Fully modded NES  (Read 63890 times)
AlanS17
    • AlanS17
Re: My Fully modded NES
« Reply #80 on: July 19, 2005, 12:32:57 am »
I don't have the skills to pull off a stunt like that with a DC. However, I have 5 NES's here at home, and a mini-itx board not going to use. Maybe it's about time I got started!
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
« Reply #81 on: July 19, 2005, 12:16:53 pm »
Or you could go all out and get a slot-loading drive. Slide the CDs in just like cartridges.
Oooooohhhh, you could even mount the drive in the original NES spring tray for even more stupidity... I mean nostalgia!
I wasn't aware they made Slot Loading GD Roms for DreamCast.  If you meant to just hook up a PC Slot loading CD Drive then you wouldn't be able to play retail copies of DreamCast games because they come on GD-Roms.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #82 on: July 19, 2005, 12:39:03 pm »
But if it could interface with the Dreamcast then I'm guessing you could chip the dreamcast to make it able to play backups on CD-R  (or preferably DVD-R).
Best Kid iPad Apps
« Reply #83 on: July 19, 2005, 12:41:45 pm »
The DC does play backups on CDR without mod.
spiffyshoes
« Reply #84 on: July 19, 2005, 05:58:50 pm »
Well yeah but is every DC game you have a back up?
JB
  • Last login:October 21, 2005, 10:56:01 pm
« Reply #85 on: July 19, 2005, 10:02:38 pm »
If you read the post I was replying to, he'd moved on to making a mini-ITX or PS2 machine. MiniITX is what I was thinking of, as I gather using a standard drive on any console(XBox excepted) is something of a pain in the butt.
« Reply #86 on: July 20, 2005, 09:26:49 am »
I don't have any backups.  The point was that it shouldn't really matter.  You can make your own backups.
shmokes
    • Jake Moses
« Reply #87 on: July 20, 2005, 02:21:25 pm »
I have a CD burner.
Best Kid iPad Apps
« Reply #88 on: July 20, 2005, 03:13:41 pm »
I forge my backups from raw materials with a hammer and anvil.  It takes a while but my CDs NEVER scratch.
shmokes
    • Jake Moses
« Reply #89 on: July 20, 2005, 05:42:15 pm »
I don't know how useful it would be anyway.  If I did this I would ABSOLUTELY wire it to use regular NES controllers instead of the cramp-inducing dreamcast controllers -- for comfort, but mostly for authenticity.  That would pretty much make it useless for playing Dreamcast games I guess.
Best Kid iPad Apps
Daniel270
  • Last login:April 10, 2011, 12:34:14 pm
  • Older Than PONG!!!
« Reply #90 on: July 20, 2005, 08:51:12 pm »
I'm guessing that to use a PS1, it would have to be modded? and if so, which mod would be needed?
I Haven't Lost My Mind, It's Backed Up On Disk Somewhere.
« Reply #91 on: July 21, 2005, 08:40:34 am »
What's the point of putting a PS1 in there?
spiffyshoes
« Reply #92 on: July 21, 2005, 11:23:17 am »
Well there is an NES emulator for PS1 but I don't remember it working very well.  It had allot of slow down and the sound was glitchy.  Maybe they have made some improvements to it since I last tried it out.
daywane
  • GRRRR!
« Reply #93 on: July 21, 2005, 12:52:05 pm »
it might be nes works well.
dramcast might be better .
I use the ps1 version at the lake.
Flappz
  • Last login:March 22, 2013, 06:42:37 am
  • My 6 Year Old Plays ATARI BITCHEZ!
« Reply #94 on: July 22, 2005, 11:13:08 am »
Does Nester 6.0 Support the Light Gun? CAn I jsut add the light gun files from 7 to 6?  I like the menu from 6 better than 7,  is there a way to just change the menu in 7 to the one from 6?
daywane
  • GRRRR!
« Reply #95 on: July 22, 2005, 01:33:49 pm »
I would use the $8.00 chip (stealth chip) I think it was like $8.00 out of canada.
been a few years since I moded a ps1.  8 wires if I remember right. was not to hard to do. 1 wire was a pain but I did it and my hands were shaking bad
Flappz
« Reply #96 on: July 22, 2005, 03:05:28 pm »
Heres the Sinny homies!!!
I have many backups of Dreamcast games, but you cannot just burn them and they will play.  But you DO NOT have to buy a $5 mod chip either.   I have tested many differend games with many different brands of software and there is only 1  that actually works for dreamcast games. Thant is Alcohol 120% ( not 52% ).  People will tell you to use Disk Juggler but it does not work I have wasted many cd's on that stupid program,  Alcohol burns DJ images no problem whatsoever.  Roxio 6 and Higher is the best for burning XBOX bac-ups, I have done a few dreamcast games, but not all of them were a success.  The XBOX images burned with no problem though. So Alcohol 120% is the BEST!!!!  Even with the NesterDC ( NES Emulator ) I used Disk Juggler & Nero and every time no matter waht I did different it did NOT work.  The first time with Alcohol 120%  it came out perfect!  DAmmit I wasted 20 cd-r's on Nero and DJ!!!!
Peace out Ninja Nerdz!
Flappz
« Reply #97 on: July 22, 2005, 03:07:36 pm »
I have no idea what that guy just said.
pointdablame
« Reply #98 on: July 22, 2005, 04:21:11 pm »
Flappz
There is a lot of bad info in this post.  You can certainly use Discjuggler to burn Dreamcast backups.  I've also used Nero with no problems whatsoever.  Alcohol 120% is great, but you don't HAVE to use it.. you just apparently have trouble getting other programs to work.
Also, during the time I was in the Dreamcast scene, Roxio was practically the worst choice you could make to burn copies.  Dreamcast is concerned with a quality image, slow burn speed, and quality media.  For the most part, burning application means absolutely nothing.
As for Xbox games, again... you are much more concerned with image, burn speed and media quality.  Roxio is still an inferior choice IMHO, but they have gotten better.  You can use Alcohol 120%, Nero, RecordNow Max, and numerous other programs to burn Xbox backups with zero problems at all.
I would also recommend Alcohol 120% to people, but not because its the "only thing that works"  You are having some troubles with your system, settings, or frankly... its a case of PEBKAC.  You can most certainly use almost any burning programs to create Xbox backups, and there are quite a few good reliable choices for Dreamcast as well.
Later Ninja Nerd.
first off your and idiot
spiffyshoes
« Reply #99 on: July 27, 2005, 12:54:16 am »
Wow thanks for the tip.
daywane
  • GRRRR!
« Reply #100 on: July 27, 2005, 08:49:38 am »
ooooooooo!
 I want one  8)
change that. I want 2  ;)
spiffyshoes
« Reply #101 on: July 28, 2005, 11:56:31 am »
If I get time I'll make you a pair.   ;)
shmokes
    • Jake Moses
« Reply #102 on: July 28, 2005, 12:29:25 pm »
The only problem with doing it that way is that the pads can't plug in nicely to the front of the Nintendo.  That might be a decent tradeoff if you could manage to get a slot-loading CDROM drive in there so you could play your Playstation games on it too, but if changing discs is excessively difficult there's not much reason to have the capability of playing Playstation games IMO.
Best Kid iPad Apps
« Reply #103 on: July 28, 2005, 01:37:18 pm »
At which point you may as well just keep your PS1 intact.  All you have there is a PS1 with a different case.
spiffyshoes
« Reply #104 on: July 28, 2005, 05:38:48 pm »
Well it isn't like you didn't have to modify the controller ports area on the NES case to fit the Atari Cables in there any way.  So what is the big difference if you put some Playstation Ports on it instead of Atari ones.  The advantage would be that you could use any playstatoin controller and even plug in a lightgun.  Although the playstation nes emulator doesn't currently support lightguns it might eventually.
Who cares about playing Playstation games on it?  I mean I thought the whole point was to have something that looked like an NES and could play every NES game.  It would be dedicated to playing NES games.  I don't see anything special about playing Playstation/DreamCast games on a NES.
I don't see how that is any different than putting a dreamcast in a NES case.  All you would have is a Dreamcast with a different case.  I thought that was the point.
« Reply #105 on: July 28, 2005, 06:36:18 pm »
No, it's not the point.  The point was that he had a dedicated NES emulator running in an NES.  With the NES case closed, he would not be swapping in DC games, particulary using a hacked NES controller.
The point was to have a reliable NES with all games on one medium.  There is nothing in that design that suggests playing DC games.
spiffyshoes
« Reply #106 on: July 28, 2005, 07:42:39 pm »
Oh ok sorry, I thought your comment was directed at me.
dogg0
  • Last login:December 14, 2014, 01:18:29 pm
  • ALL? no ALL!!!
« Reply #107 on: July 29, 2005, 12:32:17 pm »
« Last Edit: July 29, 2005, 01:07:10 pm by dogg0 »
thou shalt not supress flatulence
-the bassmaster general
shmokes
    • Jake Moses
« Reply #108 on: July 29, 2005, 01:20:25 pm »
What do you mean fit everything inside a controller?  He just rewired a regular NES controller to be able to plug into a Playstation as far as I can tell.  That's cool, and all, for playing an NES emulator on a PS1, but if you're going to gut a PS1 and put it inside a nintendo case to make it look all authentic I'd rather have the rewiring done between the controller ports and the PS1 guts inside the box so a regular NES controller can plug into a regular NES controller port on the front of the system.  See, that way it looks and acts just like the original (minus blowing on the contacts and pressing reset a couple dozen times to make a game work).  Unless you retain the ability to play PS1 games (which you really don't unless you get a slot or tray loading drive) I don't see any reason to have PS1 ends on the controller.
Don't get me wrong, those controllers are really cool, but they're cool for allowing you to play the games as they were meant to be played when using a PS1 in a regular PS1 case.  But they don't seem appropriate for a project like this.  They only take away from the authenticity without providing any positive tradeoff.
Best Kid iPad Apps
« Reply #109 on: July 29, 2005, 01:36:33 pm »
Yeah, if I do this, and I may, I'll be rewiring the controller port and using the original female NES port.  That way I don't have to mod NES controllers.  The only visible difference would be a new colored power LED.
spiffyshoes
« Reply #110 on: July 29, 2005, 01:49:34 pm »
Shmokes:
Ok shmokes I don't know what your talking about when you say use the origonal NES ports.
shmokes
    • Jake Moses
« Reply #111 on: July 29, 2005, 01:56:48 pm »
Well I know it's possible to wire it to a parallel port on a Mini-ITX board cos this guy did it on his project.   I see what you mean about this project being done with Atari cables, which I hadn't noticed.  But even this seems like a better solution for the very fact that I hadn't noticed.  They are about the same size as the original controller ports so it seems that they can be mounted up without taking much away from the overall effect.
Best Kid iPad Apps
« Reply #112 on: July 29, 2005, 02:00:51 pm »
Bah, the NES doesn't even use all 7 pins.
spiffyshoes
« Reply #113 on: July 29, 2005, 02:17:02 pm »
Yes but he used a PC and not a Playstation nor DreamCast.
« Last Edit: July 29, 2005, 05:30:00 pm by spiffyshoes »
« Reply #114 on: July 29, 2005, 02:19:34 pm »
Yep, I noticed the Atari ports right away... but it IS a Dreamcast.  Are you looking at the right pictures?
spiffyshoes
« Reply #115 on: July 29, 2005, 02:23:18 pm »
Yes I was looking at the right pictures.  I don't know of any DreamCast with a Parellel port.  (hint: there was a link to the pictures in shmokes post)  ;)
« Reply #116 on: July 29, 2005, 02:28:06 pm »
Ah, different one.  All you guys with run-on paragraphs and wonky punctuation make things hard to follow sometimes.   :laugh:
tommy
« Reply #117 on: July 29, 2005, 06:38:54 pm »
This dosen't really fit in here but thought it was cool.
daywane
  • GRRRR!
« Reply #118 on: July 29, 2005, 08:12:28 pm »
That is neat. The playstaion pad is a good pad to hack
spiffyshoes
« Reply #119 on: August 23, 2005, 10:27:37 am »
