Author Topic: Monitor Flipping 90 deg - Automatically  (Read 1107 times)
TRIBOY
  • Last login:March 03, 2005, 05:13:05 pm
« on: March 02, 2005, 11:01:58 am »
I have an IPac(2 player) wired and it works great. I check all the buttons with the key check and they check out.
I have just 1 problem. ???
When I hit 1SW1 (L-ctrl) and then immediately hit 1SW2 (L-alt) my monitor flips 90 degrees automatically.
I rewired and rewired, but I cannot solve this problem.
Any ideas on how to solve this problem would be greatly appreciated.
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
Re: Monitor Flipping 90 deg - Automatically
« Reply #1 on: March 02, 2005, 11:04:32 am »
The IPAC shouldn't be doing that but it's possible the frontend you are using does that.  I use AdvanceMame and I have it setup to rotate 90 degrees if I hit l-alt.  That might be the default actually.  Check the software you are running.
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #2 on: March 02, 2005, 03:17:56 pm »
The most likely explanation for this behaviour is that you video card driver has hot keys for screen rotation.  I know I had it happen to me.
Check you video screen settings and disable any hotkeys.
American Laser Games Wrapper
O2em Rom Utility
TRIBOY
« Reply #3 on: March 02, 2005, 04:46:24 pm »
Under which option do I find these "hot key" settings?
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #4 on: March 02, 2005, 04:55:49 pm »
Depends which card you have.  Im gonna have to say its most likely some hotkey thats programmed in your frontend.  For example, if you wired them differently, you could make 3 buttons be CTRL ALT DEL...the iPac makes it a keyboard.
