Author Topic: Cutting Circuit Boards?  (Read 2132 times)
Mike
  • Last login:September 22, 2005, 01:22:14 pm
  • Umm, yea about the TPS report
« on: October 31, 2002, 08:24:56 am »
Anyone know of a tool that works well for cutting circuit boards? I need something that will allow me to cut it in funky shapes so tin snips won't work. Thanks for any help.
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
Re:Cutting Circuit Boards?
« Reply #1 on: October 31, 2002, 10:14:32 am »
A razor saw would probably work fine. I use mine for plastic and wood, it'll go through circuit boards just fine.
Plastic modelers use them, you'll find them in any well stocked hobby store.
Here's a pic.
http://www.hobbico.com/tools/hcar0240.html
If you build a frankenpanel, chances are I don't care for you as a person.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #2 on: October 31, 2002, 11:33:40 am »
You might want to use something like a coping saw instead.
« Last Edit: October 31, 2002, 11:34:05 am by JustMichael »
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #3 on: October 31, 2002, 11:53:34 am »
I'd bet a dremel with the appropriate bit would work as well...
rampy
liche
  • Last login:November 13, 2007, 08:05:18 am
  • This is my BOOMSTICK!
« Reply #4 on: October 31, 2002, 11:56:47 am »
A scroll works also.
Just remember, that fiberglass dust (from FR-4) type boards is extremely hazardous.
You'll need to wear some sort of dust mask when cutting it this way since the dust will be everywhere.
Mike
« Reply #5 on: October 31, 2002, 12:13:58 pm »
I think I'm gonna try a coping saw. The razors don't work fast enough. I've been going at it a while with several different exacto blades and a utility knife and I'm getting no where fast. Thanks of the suggestions. I didn't know if there was some tool that is designed to do it.
