Author Topic: Tips on Building Arcade Machine  (Read 1280 times)
Shredder1
  • Last login:October 17, 2022, 12:42:09 pm
« on: February 23, 2005, 12:59:47 pm »
Hey all,
I think I've finally decided that it's time to build a new cabinet that's 4 player and move it out on the porch or in the  basement as we have no real room for it in the other parts of the house.
But, does anyone have any tips or bits of wisdom to bestow apon me in the process of making this?  I'm curious a s to the final cost of wood, type of wood to use,  the best way to keep the electronics inside organized while the move is done, and the over all time it takes to build one of these things.  If I can persuade him, a friend of ours will be cutting the wood.    I have all the time in the world to put this together, so time is no factor.
Thanks for any insite :)
Neil
walls83
  • beer is good
duffjr
  • Last login:January 19, 2012, 05:50:14 pm
  • There is no dinosaur name ending in PUSS.
Re: Tips on Building Arcade Machine
« Reply #2 on: February 23, 2005, 01:19:12 pm »
make sure your sprinklers aren't near the machine and you live in an area that doesn't rain unless you have a thick cover.
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
« Reply #3 on: February 23, 2005, 01:21:50 pm »
avoid leaving oily rags in piles on the floor while youre building your cabnet.
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: February 23, 2005, 01:25:36 pm »
Check all the sticky threads of each forum first.
GGKoul
  • Cheesecake Apprentice
« Reply #5 on: February 23, 2005, 01:44:52 pm »
Regardless if you have all the time in the world... it matters more how much money you want to spend.
Also recommend purchasing "Project Arcade" book.  It's the BYOAC bible.
NoOne=NBA=
« Reply #6 on: February 23, 2005, 02:39:23 pm »
The best tip I can give you for a 4-P cabinet is to make sure it fits through ALL the doors it needs to on the way to wherever it's going.
There's several people around here who have built 4-P cabs, only to have them somewhere they didn't want them because they couldn't get through the last door, or down a set of stairs, etc...
