Author Topic: filling in gaps around the marquee  (Read 1323 times)
DanteBK
  • Last login:June 03, 2012, 05:46:16 pm
  • The Fabulous Flying Frog-Man!
    • As Long As I Don't Have to Leave My Apartment - A Writer's Journey
« on: February 23, 2005, 09:40:22 am »
Hey - I did a search before I decided to post this, but I wasn't able to find anything on this topic.
I just installed my marquee, and there are little gaps where the light shows through around the edges. I know this happens to other people, and I know lots of those other people decide to cover those gaps up, my question is how?
Any help would be appreciated!
How's My Blogging?
dantebk.blogspot.com
Ken Layton
  • Guru
  • Technician
Re: filling in gaps around the marquee
« Reply #1 on: February 23, 2005, 09:44:46 am »
Game manufacturers use common foam rubber weatherstripping which you can get at local hardware stores. It comes in several widths and thicknesses.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: February 23, 2005, 09:46:51 am »
Go to a home reno store and look in the build-your-own-windows dept (BYOW). You should be able to find these long strips of vinyl channels, kinda shaped like this: |_,
NO MORE!!
unclet
« Reply #3 on: February 23, 2005, 12:25:50 pm »
I went to the hobby store and got some black felt (cheap).   Very easy to simply stick on from the inside of your marquee......so once the marquee is mounted then no light will escape.
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
« Reply #4 on: February 23, 2005, 04:17:16 pm »
The ultra-budget way is to just stick some electrical tape in behind the marquee where the light is shining through.
The smart way is as mentioned above: use either rubber, vinyl or wood to make a thin lining behind the marquee to stop light creeping through the edges.
hatrick
  • Last login:January 23, 2020, 12:47:20 pm
  • Big Brother is Watching You!
« Reply #5 on: February 24, 2005, 03:28:03 pm »
I used the ultra cheap black electrical tape method and it worked good enough for me.  ;)
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #6 on: February 24, 2005, 03:29:17 pm »
Go ultra cheap...nobodys gonna see behind your marquee.
